What is the weatherstripping called that goes around the front, top and
rear parts of the driver and passenger windows? The on-line sites do not show a good pic of these items. All show the weatherstripping in a roll form. Are there any good pics out there. My driver side needs replacing so bad. Thankyou.
The front is called the A pillar and it goes up the left side of the windshield, across the top and back down the right side of the windshield. It's a long piece. Willcox calls it the Windshield Header and Pillar.
The roof panel weatherstrip is just a short 18 inch section that I'm sure you can see.
The rear part is the B pillar and that goes from one side of the car to the other. Up the back of the door glass, across the roof, down the other side. Willcox calls it the Door Glass Rear and Rear Roof.
speaking about the A and B Pillar weatherstripping, how hard of a job is it for a person with no previous experience to remove the old and replace. What tools and/or chemicals would be needed.
I ask because the weatherstripping around my rear window was replaced by the previous owner and in the front/drivers side corner it is definitely not attached or cut correctly, and is a sore spot with me. I'd like to replace all the "major" pieces but don't know if I can do this job myself. Anyone with advice?
just bought some weatherstripping from wilcox, good guys to deal with....definitely recomended.
jon
Just did mine on my 95,the A&B pillar. the hardest thing was cleaning out the retainers of the old glue. GM gluded the $hit out of them. I made my own cleaning tools out of old small screw drivers. I used aftermarket Latex from Lonestar
I used a can of gasket remover (COVER YOUR PAINT) and a paint can opener to retrieve all of the old bits of weatherstripping. Worked fine. Not a particularly hard job, just time consuming.
