Bose issues.
Old Jul 20, 2010 | 11:27 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default Bose issues.
I have a 02 camaro. Front speakers sound blown. I dont understand bose. Speakers or pre amps?
Thanks for replies.
Mike
Old Jul 21, 2010 | 05:45 AM
CorvetteMike2024
Corvette Enthusiast
bose bump
Old Jul 21, 2010 | 06:34 AM
BILL-L's Avatar
BILL-L
Default bose
Hi Mike I had the same problem . Go to www.carsterohelp.com, they are bose specialists and there is a lot of info on that site . Hope it helps
Old Jul 21, 2010 | 07:29 AM
jeffp1167's Avatar
jeffp1167
Thanks for replies.
Mike
You sure it has bose? My 97 which probably has the same a,/fm theftloc C/D isn't a bose/.
Old Jul 21, 2010 | 07:31 AM
nutz4c4's Avatar
nutz4c4
www.doctordons.com Mike, give him a call
Old Jul 21, 2010 | 08:41 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Most likely your amps Mike
Old Jul 21, 2010 | 10:12 AM
socalman's Avatar
socalman
St. Jude Donor '10
I'm bettin on amps in the speakers. The Bose system does not have an amp in the head, they are at each speaker instead. The amp is a small plug-in circuit board located on the speaker.
If your speakers are completely out- I think there is a fuse for the speakers, might check that as well.
Old Jul 21, 2010 | 09:03 PM
CorvetteMike2024
Corvette Enthusiast
Thanks Socal. Your avatars rock!
Mike
Old Jul 21, 2010 | 09:05 PM
Bondami's Avatar
Bondami
From: Southside of Western Norte Americano State of Confusion, ColoFornia
St. Jude '13
Mike
I was kinda digging on those avatars myself.. Its like the LL story freezeframed..
Old Jul 21, 2010 | 09:53 PM
CorvetteMike2024
Corvette Enthusiast
Hey Jeff, what have I got here. Any details on how it works? Its not a bose?
Mike
Old Jul 22, 2010 | 06:55 AM
CorvetteMike2024
Corvette Enthusiast
bump
Old Jul 22, 2010 | 06:56 AM
nutz4c4's Avatar
nutz4c4
Mike, Thats pretty much the same unit in my '02 Silverado. There are no amps on the speakers. I had blown three door speakers before I finally replaced them all. The factory speakers are pretty crummy units.
Replaced with Infinity speakers and all has been well for seven years.
Old Jul 22, 2010 | 10:10 AM
jeffp1167's Avatar
jeffp1167
Mike
looks like my 97 .... but .... that circular looking sticker on the display face is usually associated with monsoon. so it very well could be a bose. Your's is the first I have seen like that, how many speakers does it have? Think my 97 has 4 but could be wrong, I believe the bose head unit in this car is not like the vette and the amplifier is built into it.
try turning the SCV power **** up and see if that helps.
Okay I read a little bit on this, there does seem to be a amp in the car it is located by the spare tire. It is nothing like what the 90-96 vettes use nor is there a CDM with your setup. Just replace the speakers and if the still don't work buy the amp it's not that expensive. But there were two versions of the amp one for 6 speakers and one for 8. You will need your RPO code to determine what system you have.
To Bose issues.
