Wtf?!?!
Old Jul 21, 2010 | 02:00 PM
techvette's Avatar
techvette
Default Wtf?!?!
I just took my car in for a rear tire rotation...They are directional, so you need to pop them off the bead and turn them around. I did this because there is more wear along the inside edges than the outside, one tire much more so...I think I found out why!
The guy at the shop pointed out that there was one 285 and one 255 on the back! The other 285 was on the front.
The tires have been on the car for 13 months 17K miles and I can't think of another time all four have been off the car since then! Anyway, I am squared away now...I am pissed that whoever put them on wasn't paying attention, but even more so at myself for never noticing this!
Think it's a good idea to get the car re-aligned? Do ya think running with different width tires screwed it up?
Old Jul 21, 2010 | 02:14 PM
jimmers's Avatar
jimmers
Thats pretty weird that you never noticed the size difference!
Old Jul 21, 2010 | 02:27 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Typical. I've read countless stories where the wheels have been put on wrong and the owner didn't notice for a while. Me included.
But this is a new one on me. See that's why they don't let you in the shop. None of us would let these yahoos touch our car, let alone pay them to.
Old Jul 21, 2010 | 02:28 PM
romankrzy's Avatar
romankrzy
Those are the stock sizes for that car, I just did a ton of research on them since I replaced all 4 when I bought it. Typically you don't rotate these. You might want to look at alignment or suspension if you have uneven wear.
Old Jul 21, 2010 | 02:33 PM
socalman's Avatar
socalman
St. Jude Donor '10
I'd be getting new rubber
Old Jul 21, 2010 | 02:34 PM
96 Vette CE's Avatar
96 Vette CE
Banned Loser
From: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
Yes they are the right sizes but both 255's belong on the front
Old Jul 21, 2010 | 02:47 PM
romankrzy's Avatar
romankrzy
That's what I get for multitasking and not taking the time to read, thanks.
Old Jul 21, 2010 | 02:58 PM
techvette's Avatar
techvette
All of the tires have a decent amount of life left in them...The 255 that was on the back is worn on the inside part of the tire, that one I will probably replace in the near future...
Old Jul 21, 2010 | 03:13 PM
1stvet87's Avatar
1stvet87
Even with mismatched tires on rear i would suspect either a camber or toe issue on the rear since your rear tire was only wearing on the inside. Don't know about where you are but here in central Texas, Firestone used to do free alignment checks. Meaning they would check the alignment and let you know if it was in or out. Of course they would love for you to go ahead and get one done if it needs it. Actually they used to have a good deal on lifetime alignments, pay once and have done for free then on. Now the disclaimer: Use Firestone at your own risk, like any other place they can have good tech's and not so good tech's. (used to be service manager at a Firestone)
Old Jul 21, 2010 | 03:24 PM
romankrzy's Avatar
romankrzy
I had mine aligned when I got the new tires and the right rear was way off, I'm glad I had it done.
Old Jul 21, 2010 | 03:36 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Old Jul 21, 2010 | 03:55 PM
bk84vette's Avatar
bk84vette
My car had THREE different brands of tires on it when I first got it!
Old Jul 21, 2010 | 04:56 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
For sure
Old Jul 21, 2010 | 05:01 PM
astepup's Avatar
astepup
Would having two diff size tires on the rear for 17K miles screw up the rear end gears/posi unit? A 285 tire IS slightly taller than a 255 isn't it?
astepup said that
Old Jul 21, 2010 | 05:09 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Do you really want to wonder about it while you are going fast through the S's, align
Old Jul 21, 2010 | 05:12 PM
cal55's Avatar
cal55
astepup said that
I believe it's just wider.
Joe
Old Jul 21, 2010 | 05:36 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
astepup said that
Joe
Actually, the 255 is slightly taller. But not enough to even make a difference or hurt anything.
The 285 as stated is wider though.
255/45-17 = Approx. 26.04" Diameter
285/40-17 = Approx. 25.98" Diameter
So, the 255 is 0.06" taller.
That is a general tire calculation. Different brands very well could measure slightly different.
To Wtf?!?!
Old Jul 21, 2010 | 05:46 PM
astepup's Avatar
astepup
See? THAT'S why I love this place....always learning something...but wait...that also means I didn't know everything in the first place.....uh oh...maybe my ex g-f was right after all
astepup said that
Old Jul 21, 2010 | 05:52 PM
romankrzy's Avatar
romankrzy
astepup said that
Here's more information than you could ever want on tires and wheels.
http://www.tirerack.com/about/techcenter.jsp
Old Jul 21, 2010 | 06:16 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
They're never right!
