r12 to r134 conversion
from the limited research I did on the subject, I consider it as done "correct and by the book." i'm by no means an expert on the subject, and I'm sure others will disagree on what I did or didn't do, but all I can say is, I have cold air, and haven't had issues in the three years since the conversion. it may not be the coldest air possible for the system, but it's cold enough for me, and i'm a happy camper! I went with 134a vs R12 since I was rebuilding the system, and that seemed to be the route to go at that point in time. i'm NOT sorry I did it by any means.
note - I did not change out my hoses for R134a rated assemblies. new service replacement delco's are 134a rated - I bought them, and the one's I got didn't fit for schitt - couldn't use them. I had a rather nice set from a low mileage 86, so I cleaned and installed those. while they are not 134a rated, I haven't experienced anything that's noticeable in the car's cooling. i'll probably check pressures this summer, and may (or may not) have to add Freon, but if I do, it should be minimal. I briefly had my AC on several weeks ago, and it was still pumpin' out cold air, so i'm guessing everything's still good.
as for just changing your fittings and just adding 134a - some folks around here have had success with the "$39 conversion in the can" from Walmart. short term, I guess it will work - long term - who knows? the main issues is the system's oil and O-rings. most likely, the oil mix will turn to goo, and you'll have to deal with that at some point in time. again, i'm no expert here - personally, I wouldn't do it.
Includes fittings and oil.
