Manually lowering windows???
Old Jul 23, 2010 | 09:44 PM
Cyclonite's Avatar
Cyclonite
Default Manually lowering windows???
Is there a way to manually lower electric windows? I've done the truble shooting to the point of where the FSM says "replace switch", and doubt the switch it the problem. I've pulled the connector to the regulator motor and put a voltmeter to it and when I hit the switch I got power at the connector, so I believe it's the regulator motor.
This is for a '92 I am making into a track car, and need to have the window down while on the track. Eventually I want to remove the glass completely, but I couldn't get it out. It looks like I need to have the window lowered a bit to be able to maneuver the glass out.
Old Jul 24, 2010 | 09:08 AM
jeffp1167's Avatar
jeffp1167
You can get it all apart with the window in the up position. However if that dioes not work simply remove the 3 torx screw that hold that rectangular part of the motor on and slip it of then turn the armature and the window will come down. I basically bought new motors and swapped the new electrical parts onto my old motors transmission so I didn't have to deal with the pop rivets and the work great now.
Old Jul 25, 2010 | 11:16 AM
Cyclonite's Avatar
Cyclonite
Thanks, I'll see if I can get my gorilla hands into the interior and pull the motor apart. If not I'll just have to work harder at getting the glass out the way it is.
Old Jul 25, 2010 | 11:36 AM
ElvisGraceBo's Avatar
ElvisGraceBo
A hammer will get that glass down, in a hurry too.
Old Jul 25, 2010 | 12:10 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Or just leave it over night in a bad area.....
Old Jul 25, 2010 | 03:29 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
Old Jul 25, 2010 | 04:10 PM
ch@0s's Avatar
ch@0s
Old Jul 25, 2010 | 09:26 PM
Cyclonite's Avatar
Cyclonite
Originally Posted by ch@0s
Thought about that already but I'd probably be able to sell the window for more if it's only in one piece
To Manually lowering windows???
