Air Conditioning
Old Jul 23, 2010 | 09:58 PM
1986c4BrownMetallic's Avatar
1986c4BrownMetallic
Default Air Conditioning
Hello all, my vette currently has no AC n when i bought it it came with one of those R-134 AC chargers or something....i was wondering the best way to fix this problem....charge it myself or do convert it to the new AC system?
Old Jul 23, 2010 | 10:10 PM
big wave's Avatar
big wave
134a is the replacement for r-12. Ask corvvete mike first. But 100% sure on this . If your system has a low or high pressure switch, ohm the switchs. Run the car a check for pressure on the low and high side to see if you do have 134a in your lines as well.Do you have or know someone with a manifold gauge set.?
Old Jul 24, 2010 | 06:19 AM
romankrzy's Avatar
romankrzy
Make sure you have the 134 low pressure / cycle switch if it was converted. Mine was converted when I bought it and they did not change the switch so the PO had a toggle switch on the side of the driver seat to ground out one side of the R12 LP switch for AC which did not cycle as it should. I replaced it with a 134 LP switch and took the toggle switch out, it now works the way it should.
Old Jul 24, 2010 | 12:26 PM
1986c4BrownMetallic
I have the old system now. I wonder if it would be better in the long run to convert to the new A/C system or use this R-134a recharging bottle that came with the car
Old Jul 24, 2010 | 12:31 PM
jhammons01's Avatar
jhammons01
If you have the kit....and the system does not work now.......install the kit and call it a day
It'll take you 20 minutes.......
If you decide to "go back" the other way...you'll have to have a pro do the work anyway.
Fill the system with 134a, run it for a few days.....most likely you have a leak which is why it is not working today.....
If it is an acceptable leak.....just refill it every 6 months like I do......if it leaks out in a few days....you'll have to "Address" the system differently.....(AKA $$$)
Old Jul 24, 2010 | 09:08 PM
BADRACR1's Avatar
BADRACR1
I change every car I get with R12. I've done ten cars or so, no problems with any yet. It works best if you have a way to pull a vacuum first. The R134a works just as well, but you only use about 75/80% of the amount originally required.
Old Jul 25, 2010 | 04:27 AM
mazdaverx7's Avatar
mazdaverx7
what i would do is buy a new o-ring kit and install a new ring in every location that takes an o-ring. if you retrofit, the R-134 may not be compatible with your old o-rings and you can quickly develop a leak. re-o-ringing takes a few hours but it'll be well worth it.
To Air Conditioning
