Normal oil pressure
Old Jul 25, 2010 | 12:38 PM
ps374's Avatar
ps374
Default Normal oil pressure
With the digetal dash what is the lowest acceptable oil pressure on a high mileage engine? How low do the numbers have to be before the warning light comes on?
Old Jul 25, 2010 | 12:42 PM
vader86's Avatar
vader86
I think my warning light didnt come on til it was 6psi, so dont think that will save ya.
spec is 45-60psi at cruise, higher when the engine is cold
idle spec hot will be 20-30psi
idle cold will be in the 50s
as a rule you need 10psi per 1K RPM the engine is running
