Corsa Outer Tips Functioning Video Proof.
Old Jul 28, 2010 | 03:10 PM
GKK's Avatar
GKK
Default Corsa Outer Tips Functioning Video Proof.
Here Again..., is a Video I made years ago showing proof that Both Corsa exhaust tips do Function. I also, posted this in the C4 Tech/Perf section.
Many members here Insist that the outer tips are dummy's, probably confused by this picture which if you look very closely, you can see a small diameter exhaust tube (circled) that flows exhaust inside and Around the baffle and exits out of the outer tip. This exhaust flow is not for Performance but, is part of the muffler design to eliminate Resonance.
Anyways, This Corsa system is installed on my "91" L98. The tennis ***** are a perfect fit and are pressed in tight.
Here you can see the exhaust flow by watching the attached Ribbons.
Here you can see the Primary tips blocked by the Tennis ***** and the Outer tips still flowing exhaust. This exhaust flow (or leak) is very minimal and is used in part to help eliminate Resonance.
Old Jul 28, 2010 | 03:12 PM
Sweet 90's Avatar
Sweet 90
Finally, we can put this myth to bed
Old Jul 28, 2010 | 03:15 PM
darkstallion_69's Avatar
darkstallion_69
well done. obviously they flow air just not as much.
Old Jul 28, 2010 | 04:14 PM
ElvisGraceBo's Avatar
ElvisGraceBo
My corsas only flow thru one ....
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Jul 28, 2010 | 04:22 PM
Sweet 90's Avatar
Sweet 90
Oh dear God
Old Jul 28, 2010 | 04:36 PM
socalman's Avatar
socalman
St. Jude Donor '10
I guess I'm blind- looked like the inner ribbons were going nuts and the outers were gettin a slight breeze. The picture looks like it's plugged to me, a poorly designed plug that allows exhaust to pass.
Old Jul 28, 2010 | 04:42 PM
ElvisGraceBo
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I wonder if there would be any benefit from opening up the other one with a drill bit or something??
I used to have some Borla's that were both open. It sounded great..
Old Jul 28, 2010 | 04:50 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
Oh dear God
Old Jul 28, 2010 | 04:58 PM
Sweet 90's Avatar
Sweet 90
Yes, resonance
Old Jul 28, 2010 | 05:01 PM
Sweet 90's Avatar
Sweet 90
You're not blind bro. Most think that the outer Corsa tips are non-functional period. All though they are not a true dual flow; the video shows that they are NOT a dummy tip
Old Jul 28, 2010 | 05:12 PM
GKK's Avatar
GKK
These videos show that the Outer tips do work and are Not Plugged.
Inner tips = Primary Performance exhaust flow.
Outer tips = Auxillary exhaust flow.
I don't know how much simpler I can make it.
Last edited by GKK; Jul 29, 2010 at 09:24 PM. Reason: Exhaust flow too control Resonance (changed)
Old Jul 28, 2010 | 05:17 PM
Sweet 90's Avatar
Sweet 90
Originally Posted by GKK
These video show that the Outer tips do work and are Not Plugged.
Outer tips = Exhaust flow too control Resonance.
Should have used half-naked women to explain it
Good work btw
Old Jul 28, 2010 | 05:27 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
Sweet 90 for president and I await your State of the Union address...
Old Jul 28, 2010 | 05:28 PM
Sweet 90's Avatar
Sweet 90
I wasn't born in the US. Oh wait...... maybe that doesn't matter any more
Aurora40's Avatar
Aurora40
What is the point of this? If the outer tip didn't flow, it wouldn't make any performance difference, since the tip internal diameter is the same as the rest of the system. So there's no restriction from the fact that most of the flow goes through the inner tip.
It does have the ability to flow. But in practical terms, you only get sooty crap on the inner tip. And in the winter you only see vapor out of the inner tip. So in most of the sense that people care, the outer tip is not functional.
Old Jul 28, 2010 | 05:35 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Back in 1997, Corvette Fever published an article on all aftermarket exhaust system. Using the same Vette (GS) the dyno few systems.
I dont care if Corsa's system blow out of one or two.
Which exhaust system frees the most horsepower? (I say free because the only way to create HP is by modifying the powerplant)
Old Jul 28, 2010 | 05:36 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
That's the rumor...
To Corsa Outer Tips Functioning Video Proof.
Old Jul 28, 2010 | 05:54 PM
socalman's Avatar
socalman
St. Jude Donor '10
Old Jul 28, 2010 | 06:32 PM
jeffs40thgtp's Avatar
jeffs40thgtp
i think ill just stick with borla
Old Jul 28, 2010 | 07:16 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
from your description you are correct they both do function.
Last edited by RetiredSFC 97; Jul 28, 2010 at 08:11 PM. Reason: No reason to be a SA
