adding larger wheels to C4
Old Aug 1, 2010 | 10:17 PM
oldtvman's Avatar
oldtvman
Navigator
Default adding larger wheels to C4
I bought a set of wheel spacers from Ecklers some time ago and I have a set of wheels and tires from a c6, trouble is when I installed the new set, some of the lugs on the spacers kept coming loose, I will probably try using lock washers unless someone else has a better idea.
Old Aug 1, 2010 | 10:29 PM
Blame's Avatar
Blame
I got C6 ZO6 rim on my baby. Got the 1 1/4 adapters and never had that trouble. I did torque them to 125 lb. You should try that.
Old Aug 1, 2010 | 10:37 PM
socalman's Avatar
socalman
St. Jude Donor '10
the lug nuts should be tapered which will center the adapter. If you use lock washers, you may offset the adapter and get a wobble. Gotta crank em, like the other poster said.
Old Aug 1, 2010 | 10:38 PM
maroon88iroc's Avatar
maroon88iroc
125 ft pounds seems high, Be careful overtightening the wheel to the spacer b/c those studs turn/break off in that aluminum spacer mighty easily.
I run spacers on my buick grand national and I had a problem breaking the studs off the rotor and of course that is inside the spacer and you cant tell if there is a problem untill removing the wheel. I take all the wheels off every once in awhile to make sure they are all ok b/c when the ones broke off on me before the wheel almost came off which would not have been good.
Old Aug 1, 2010 | 10:45 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
You should use adaptors, not spacers. Adaptors bolt onto the original studs and have their own studs for holding the wheel. With spacers you should replace the original studs with longer ones to give the lug nuts enough length to seat properly.
Old Aug 1, 2010 | 10:48 PM
maroon88iroc
Originally Posted by jrzvette
You should use adaptors, not spacers. Adaptors bolt onto the original lug bolts and have their own bolts for holding the wheel. With spacers you should replace the original lug bolts with longer bolts to give the lug nuts enough length to seat properly.
Idk if you were talkin to the OP or me But the ones on my buick are adaptors. most people call them spacers because it is the same bolt pattern on both sides... Im sure the op has the same kind tho b/c that is what is common.
Old Aug 1, 2010 | 10:50 PM
Blame's Avatar
Blame
Originally Posted by maroon88iroc
125 ft pounds seems high, Be careful over tightening the wheel to the spacer b/c those studs turn/break off in that aluminum spacer mighty easily.
I run spacers on my Buick grand national and I had a problem breaking the studs off the rotor and of course that is inside the spacer and you cant tell if there is a problem until removing the wheel. I take all the wheels off every once in awhile to make sure they are all OK b/c when the ones broke off on me before the wheel almost came off which would not have been good.
For the corvette it call for a 100lb of torque to each lug nut. Adding 25 more lb won't break a lug, unless you are putting a lot of force behind it.
Old Aug 1, 2010 | 10:52 PM
socalman's Avatar
socalman
St. Jude Donor '10
to clarify- do you have these (adapters)
Old Aug 2, 2010 | 07:43 PM
oldtvman's Avatar
oldtvman
Navigator
yes those are the ones bought them from Ecklers
Old Aug 2, 2010 | 08:46 PM
gkrynick22's Avatar
gkrynick22
I have spacers on my 85 and I had spacers on my T/A for over a year with absolutely no problems. My theory is spacers are fine for normal street use. For the strip I would go with adapters for that little extra strength. My T/A had headers, full exhaust, 4.10 gears, and a tq converter. I drove it pretty hard and never had any problems with the spacers.
Old Aug 2, 2010 | 08:51 PM
gkrynick22's Avatar
gkrynick22
I assume you must have replaced the studs for longer ones right? You could try a SMALL dab of "removable locktite" on the bolt. I would not use the washers because of what Socalman said, they are tapered and meant to center the rim.
mbowers13's Avatar
mbowers13
From: https://www.facebook.com/groups/OrangeCorvettes/
I used adapters, torqued them to about 100 if I remember. Did fine for me.
Old Aug 2, 2010 | 09:10 PM
socalman's Avatar
socalman
St. Jude Donor '10
did you replace the wheels studs (you didn't need to- but if the nuts are coming loose in the adapter, maybe the new studs weren't pressed in all the way?).
If not, when running adapters- crank the nuts just like you would the wheel lugs- 100lbs. Then, remove the wheel after 50 miles and check the torque on the adapter bolts, just as you are advised to do when installing (or re-installing) new wheels.
To adding larger wheels to C4
