AC Question
Old Aug 7, 2010 | 09:34 AM
daddysvet92's Avatar
daddysvet92
Default AC Question
1992:
I see that my clutch is not turning when I have the AC on inside the car. Does this mean my compressor needs to be rebuilt/repaired? Should I check anything else first?
Is this a self do project or do you need a pro to rebuild it?
Is there a kit to buy to rebuild it?
Are there any steps to taking apart and getting this fixed?
Chris
Old Aug 7, 2010 | 12:09 PM
aminnich's Avatar
aminnich
No, it is more likely a sign of low freon. In the case of low freon the binary/trinary switch cuts power to the clutch to keep from burning up the compressor. There could be other problems, but low freon is the most common.
