Fuel filter replacement ?
Old Aug 8, 2010 | 10:41 AM
joesgulfstream's Avatar
joesgulfstream
Default Fuel filter replacement ?
I am going to be putting in new injectors from Jon from FIC in my 95 with 69000 miles, not sure how old the filter is I really don't want to change it because of all the stories i have heard. Is it really that bad of a job ? what should I do,don't want to mess up new the injectors .
Old Aug 8, 2010 | 10:51 AM
nypearson's Avatar
nypearson
It's not that bad. I searched tech for step by step and went from there. I disconnected one hose from underneath and pulled it up through the engine comp. Just make sure to pull the fuse first. also have a container ready for gas from the hoses.
Old Aug 8, 2010 | 12:23 PM
c4cruiser's Avatar
c4cruiser
The fuel filter can be a pain to access and remove. There may be a small heat shield to remove to get to the filter.
To keep the gas spillage to a minimum, there are a few tricks. The fuel rail on the passenger side has a Schraeder valve that will allow you to release fuel pressure at the rail. You can also pull the fuel pump fuse and start the engine and let it idle until it dies. It's a good idea to raise the front of the car as high as you safely can so that gravity won't cause gas to drain from the tank. Have as little gas in the tank as possible.
You will need flare wrenches to remove the front and rear parts of the fuel line. Don't try open-end wrenches or Crescent wrenches; you don't want to round off the nuts.
If you don't want to mess with doing it yourself, take it to a reputable shop and have them change it before you do the injector swap.
Old Aug 8, 2010 | 12:32 PM
tblt44's Avatar
tblt44
this is how I did mine,I could not get anything on the top nut to loosen it(mine was real tight).pull it up thru the engine compartment and its a breeze.
Get yourself 2 new o rings for the line also mine was shot.
Old Aug 8, 2010 | 12:42 PM
joesgulfstream
I could not find anything on how to pull it through the engin compartment can the o rings be purchased at auto store or are they GM only? any help on finding link on fuel filtter replacement through the engin compartment , I would be thankful
Old Aug 8, 2010 | 01:21 PM
tblt44's Avatar
tblt44
Here is mine from about a year ago
You will have to buy a pack with many size o rings(about 5 bucks at any auto parts store)make sure you get the orange kind safe for fuel
http://forums.corvetteforum.com/c4-t...as-a-joke.html
Old Aug 8, 2010 | 01:23 PM
andy95's Avatar
andy95
Hey Joe, been toying with the same task myself (fuel filter/pressure reg)...still "researching" and trying to find time to do it. I found this post with lots of good info and pics to boot! Good luck!
http://forums.corvetteforum.com/c4-t...on-a-95-a.html
Old Aug 8, 2010 | 05:04 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
I don't know where they are on a 95 but on my 90 the biggest issue was getting under the care to get to it. After that fiasco it went pretty smoothl. I agree with relieving the pressure as mush as possible and have something ready to collect the fuel that does drain.
Old Aug 11, 2010 | 11:36 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
For safety's sake, be sure and disconnect your battery after you've removed the fuel pump fuse, started the engine, and allowed the fuel to run out of the line.
It's all too easy to accidentally create a spark with your tool and the starter solenoid, knock sensor shields, or other metal components while you're underneath there.
Old Aug 11, 2010 | 12:08 PM
pitchadude's Avatar
pitchadude
We lifted mine....removed shield. Took off line on bottom. Put socket on the bottom of filter with extensions and I held nut on the line on top with a wrench while a friend turned it and it came right out. Wasn't bad at all.
Old Aug 17, 2010 | 04:18 PM
Hideki's Avatar
Hideki
I'll admit this one wasn't as bad an experience as I'd thought it would be. While I don't know if the LT1 cars have a different fuel filter, on my '90 the only real pain was that even with pulling the fuse, and cranking the engine you're still gonna end up in a puddle of gas it's a little fiddly, but any novice with a jack and some hand tools can do it and feel like a hero. My C4 had a horrible problem where it wouldn't want to start from time to time, it would crank but just not fire. Changing the 20 year old fuel filter solved that problem.
Old Aug 17, 2010 | 09:54 PM
Lrod's Avatar
Lrod
Don't intend to beat a dead horse but, Turn off the pilot light to your water heater, and don't use and incancescent drop light, if the gas drips on it, kaboom. I had to disconnect my fuel pump to stop the siphon.
Old Aug 17, 2010 | 10:42 PM
Bensons86's Avatar
Bensons86
I did my 86 by myself from under the car. It wasn't a big deal at all. Just need something to catch the fuel...other than that, I just connected the other one as fast as possible and didn't really lose much anyways.
No biggie
Old Aug 17, 2010 | 10:50 PM
JackDidley's Avatar
JackDidley
I run my car low on gas and jack the front up high. Almost no gas comes out.
Old Aug 18, 2010 | 12:00 AM
primalurges's Avatar
primalurges
I've now heard of blue and orange o-rings but havent been able to find any. Local autoparts only had black. Any on-line sites?
Old Aug 18, 2010 | 01:14 AM
armybyrd's Avatar
armybyrd
Just changed mine in my '88 the other day. I jacked the car up and its really simple to change. Just a shield and new lines to break open and your done.
To Fuel filter replacement ?
