New Guy Question
Old Aug 9, 2010 | 10:34 PM
petah50's Avatar
petah50
Default New Guy Question
Hello, I'm new to the board. Just found it tonight. I'm in the market for a used corvette. I'm looking at a 1987 Convertible. Any suggestions on some key things or issues I should look out for? I appreciate any advice.
Old Aug 9, 2010 | 11:17 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
Welcome, as the car is nearly 25 years old, you should expect a number of issues.
Assuming the engine/tranny/rear are in good shape …
Some things to look out for:
Digital dash
Antenna motor
Headlight motors
Window motors
Switches (windows, door lock, HVAC, dash)
[other members will complete the list ...]
Old Aug 9, 2010 | 11:23 PM
pianoguy's Avatar
pianoguy
Here's a lot of good info about inspecting a C4:
http://www.corvette-guru.com/modules...t.php?fileid=7
Old Aug 9, 2010 | 11:36 PM
petah50's Avatar
petah50
Wow, thanks for the links and advice. That was fast!
Old Aug 10, 2010 | 08:48 AM
j-vette's Avatar
j-vette
St. Jude Donor '10
Lots of cars out there so take your time and find a good one...
Good luck!
Old Aug 10, 2010 | 09:19 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I used to own an 87 vert. Really liked it except that the choices for custom wheels were limited. There are more choices is custom wheels out there for the 88 and later C4s as they came with 17" wheels (exception was 88 base) and different backspacing than the 84-87 C4s.
In order to run the later style wheels on the 84-87 you usually must run wheel spacers.
Old Aug 10, 2010 | 09:26 AM
1st87's Avatar
1st87
not to take anything away from a vert, but there's more rear space in a coupe. So if your traveling with a friend-pack lite....
Old Aug 10, 2010 | 10:00 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
You can`t go wrong with a Vette. Just remember to look at it as a "hobby"
To New Guy Question
