Do we have an expert?
Old Aug 11, 2010 | 07:37 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Default Do we have an expert?
Do we have an expert on concrete?
Need help with foundation for lift.
Old Aug 11, 2010 | 08:03 PM
socalman's Avatar
socalman
St. Jude Donor '10
Well, you can saw cut and remove the 24x24 area in your garage, and dig it out 6" (fk that 12" shiz), drill 1/2" holes , 4" deep (embed) around the perimeter 3" off the edge and every 6"- drilling in the center of that pathetic 3" slab they gave you. Use Simpson Set XP Epoxy or Hiliti FY150 (comes in a caukling tube, sold at HD in Hardware dept. by Simpson Ties) and stuff some #3 rebar in there long enough to overlap each other. Then use 4 bags of Rapid Set morter mix per hole- white bag with dark red writing- sold at HD. Sets up fast, so use a drill and mixer bit in a wheel barrow, or 1 bag at a time in a 5 gal bucket, will be at 4000lb in 3 hours. Ready to drill for your new Max Jax.
http://www.ctscement.com/MortarMix_FAQ.asp
Old Aug 11, 2010 | 08:18 PM
PLRX's Avatar
PLRX
2017 C4 of Year
PM sent
Old Aug 11, 2010 | 08:54 PM
Jamie Lennartson's Avatar
Jamie Lennartson
What do you know.... I just happen to be a Concrete Finisher
Did a slate stamped deck just today.
Show me where you want to put the lift and the bottom base you want to anchor.
If the base is a small area it will not hold it will crack all to hell.
But you also dont have to jack hammer out that 24x24ft area.
There is a product called Flex cement that will hold and not crack.
To Do we have an expert?
