NGK plug choices
Old Aug 12, 2010 | 05:44 PM
tblt44's Avatar
tblt44
Default NGK plug choices
I see talk of the NGK TR 55 double platinum
the TR 55 I found is not platinum below
http://shop.advanceautoparts.com/web..._1091597138___
I also found this one TR 55GP
http://shop.advanceautoparts.com/web..._1091597581___
how about this one
http://shop.advanceautoparts.com/web..._1091587122___
Are any of these what you guys run??
I just don't wana pay 6.50 a plug for the A/C delco if I don't have to,they are the double platinum,which I can't find in NGK.
Also looking at rapidfire for 4.99
I just ordered my 8 mm Taylor wires,wana do all this when I have the W/P and opti off.
Old Aug 12, 2010 | 08:41 PM
tblt44's Avatar
tblt44
anyone what do you use?????? TR55 or the Tr 55 Gp
Old Aug 12, 2010 | 11:38 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
I used the TR55 copper core plug in my '93 with no problems. I just recently replaced them with a set of Autolite 606 copper core plugs (I couldn't beat the price). No problems with the 606's.
Old Aug 13, 2010 | 04:52 PM
tblt44's Avatar
tblt44
So you didn't use a platinum.
Did it run just as good as the ac delco platinum plugs????
Old Aug 13, 2010 | 07:52 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
You are going to make me go to the garage and look at the last box I have
BRB
NGK Vpower TR55 3951
Old Aug 13, 2010 | 07:56 PM
Andrew's Avatar
Andrew
TR 55's, copper core. I like them because they are inexpensive and that is important to me since I have to change them out so much. If you are thinking about N2O, you would want a cooler plug.
Old Aug 13, 2010 | 08:14 PM
tblt44's Avatar
tblt44
BRB
So why are so many of you guys going back to a regular plug over platinum???????
I was thinking a regular plug is good for say 30,000 miles it would take me 15 years to put that on my car.Is this why you guys go this route,also 2.XX a plug helps to.
Old Aug 13, 2010 | 09:13 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
OK, its not a corvette - but here is the story:
Had a 2001 Mustang V6, original plugs had 90K on them.
Replaced with BOSCH platinum plugs (just the single electrode).
What a MISTAKE, after 30k miles they were crap, replaced with the NGK TR55
Never had another problem with it until I put it in the wall at Road Atl.
On my 92 I replaced my plugs 4 years ago with the TR55. Replaced them again this year.
Now mine spends a lot of time at WOT, the plugs weren't worn, just had some fouling.
I don't like the idea of "replace your plugs every 100K miles", At $2 a plug I'll change them once a year if I need to.
Old Aug 14, 2010 | 12:08 AM
H P Bushrod
Moderator Emeritus
Yes, they did.
Old Aug 16, 2010 | 03:21 PM
onedef92's Avatar
onedef92
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I'm running NGK TR-55 Double Platinum. Cost about $2 each and they're awesome.
Old Aug 16, 2010 | 04:06 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
I have the Rapid Fires.
Old Aug 16, 2010 | 05:13 PM
hooked073's Avatar
hooked073
personal opinion I do not think there is a plug out there that you will feel a difference from on the street unless they are bad. Just about any plug with everything working the way it should give you at least 80000 miles. I usealy use Autolite or A/C It really does not matter to be have had no problem out of any plugs.
Old Aug 16, 2010 | 07:39 PM
tblt44's Avatar
tblt44
Just got my Taylor wires today,they seenm like cheap rubber
Are theses things anygood.
8 mm spiral custom
To NGK plug choices
