hi guys, i was wondering, i got full sound fromt the rears (bass,mids,highs), but up front i only get highs, like just a tweeter is there. is that normal for the bose system or are my fronts dead?
In my 95 the fronts have two speakers in each box,so it seems you are only running one if this happened to both at the same time it dosen't sound like the amps could be the CDM. Call Dr. Don if you have a lot of money to burn, if you don't than call fixworks.com
I have an aftermarket Sony..mine does the same thing ...sort of.
When in full mode all 4 speakers sound good, but when I set balance to front only, the sound isn't so good...muted, lack of highs and lows. When I turn it back to front and rear, the fronts sound great again.
Only in the fronts though. When I set to rear only, they sound the same.
