74-75 visual differences
Old Aug 14, 2010 | 01:49 PM
chadwf's Avatar
chadwf
1st Gear
Default 74-75 visual differences
What differences should one see (not underhood) between 1974-1975 corvette
thanks
Old Aug 14, 2010 | 02:00 PM
Mark_Milner's Avatar
Mark_Milner
Don't ask the C4 guys, how would they know?
Take this to the C3 section. then you will find out about catalytic converters, AIR pumps, and such.
Old Aug 14, 2010 | 02:36 PM
MidShark's Avatar
MidShark
C'mon Mark- give some of us old guys some credit!
The only thing that comes to my mind is that the rear bumper cover on a '74 has a vertical seam in the middle, and the '75 does not.
Old Aug 14, 2010 | 04:16 PM
Riks40th's Avatar
Riks40th
From: St. Louis, Mo......... 1993 Torch Red w/White Interior...2006-07 Bloomington Gold 2005-ZR1/C4 Gathering, 2001-2012 Funfest
.......split rear bumper
Old Aug 14, 2010 | 05:04 PM
RedLS1GTO's Avatar
RedLS1GTO
Yeppers... that is all that I know but I am FAR from a C3 guru.
Old Aug 14, 2010 | 06:07 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
As MidShark said, the '74 has a split rear bumper, the '75 is one piece. The '75 also had simulated pads on the front & rear bumpers, and the speedometer showed KmPH. If you look under the cars you'll see that the '74 has a true dual exhaust and no cats. The '75 has both exhausts routed to a single converter then back out as duals.
Old Aug 14, 2010 | 06:11 PM
pologreen1's Avatar
pologreen1
68-72, 80-82 for me, I won't even look at the other c3's.
Old Aug 14, 2010 | 07:02 PM
hooked073's Avatar
hooked073
arnt all 74 red and 75 black?
Old Aug 14, 2010 | 09:57 PM
jrzvette's Avatar
jrzvette
Black wasn't a factory color from 1970 - 1976.
Old Aug 14, 2010 | 10:33 PM
hooked073's Avatar
hooked073
I was joking
Old Aug 15, 2010 | 06:50 AM
vette54728702's Avatar
vette54728702
wow, that's to bad because they are Corvettes also!
Old Aug 15, 2010 | 06:54 AM
vette54728702
74 is the last year for true dual exhaust, 74 was last year for no cat converter, 74 used regular gas, ... also, I think the seat belts went through the back of the seat on a 74, 75 the shoulder strap was routed differently.
Correct about the split rear bumper on the 74
74 does not have an emblem on the gas tank lid
74 Does not have the bumper impact stubs
74 last year for Big block
Yes, I know this is the c4 section... but the op did ask.... hope this helps !
Old Aug 15, 2010 | 09:58 AM
harley 1951's Avatar
harley 1951
Wow--Split bumper ? Is that as valuable as a Split Window ?
Old Aug 15, 2010 | 10:15 AM
vette54728702
LOL, I bet the '74 owners wish it was !
To 74-75 visual differences
