C4 Insulation "Mad-Mat" Kit... $120
Former Vendor
The MadVette C4 Pre-cut Mad-Mat Insulation kit comes with everything you need to insulate and provide sound deadening in your Corvette, including Pre-cut pieces for your doors.
Other kits on the market provide a similar product, but do not provide pre-cut pieces for your doors, which with our door pieces installed, less road noise will be present in your front cabin. Mad-Mat gives you everything you need to COMPLETELY insulate your C4 Corvette.
Our Mad-Mat kit is a non-fiberglass, non-asphalt based product which weighs in at 3.5 lbs. (for those who are weight conscious), it also rejects 97% of the radiant heat, and has a manufacturer's rating of 10db of sound and road noise reduction!!!
Mad-Mat is only 3/16" thick, so as not to interfere with proper mounting of your panels and seats, and all holes are pre-cut & all pieces are clearly labeled for your convenience.
It is our #1 goal to provide you ease of install, while making a HUGE improvement in your overall enjoyment of your Corvette!!!
Each kit is hand cut to our specifications, and guaranteed to make a dramatic difference in your C4!!!
Each kit comes with the following pieces:
Say goodbye to over-heated center consoles, and noisy front cabins!! Our C4 kit is the perfect addition to your C4, and is recommended for every Corvette owner as the #1 modification for their Corvette!!!
Your Corvette will be cooler in the summer, alot less noisy, and you will be able to enjoy your Corvette so much more.
- Driver & Passenger front floorboard pieces, with holes cut for seat bolts and pedals.
- Driver & Passenger side tunnel pieces, cut around your console mounting screw holes.
- Full center console pieces, with holes for the center console bolts.
- Driver & Passenger side Door Panel pieces.
- Cargo area floor pieces.
- Full Side rear wheel well pieces.
- Full back wall and corner pieces.
- Pre-cut piece for wall behind seats.
- Extra pieces for odds and ends coverage that you may need.
Alot of research and development has gone into this kit, and we are proud to say that our kit is made to our demanding specs, in house, and cut off of our own templates.
CLICK HERE TO ORDER YOUR KIT TODAY!!
$120 plus $15 shipping in the continental USA
Here are some photos of the kit installed:
Some have emailed and asked, so here is a picture of the material, as well as some specs on the material itself:
It has 5 layers, and though it is manufacturer rated at a 19db drop in noise, I have tested it in the Vettes at 8-11 db. reduction. Here are some manufacturer specs on it:
CLICK HERE TO ORDER YOUR KIT TODAY!!Some have emailed and asked, so here is a picture of the material, as well as some specs on the material itself:
Characteristics | Value | Regulation
Cell Structure: Closed
Nominal Thickness: 5 mm (+ or - 0.5mm)
Steam Permeability: 0.033 gr/m2hkPa ASTM E-96
Noise Insulation: 19dBA IRAM 4063 at 50hz.
Flame Spread Index/Class: 25 or less/ "A" - Class 1 0 ASTM E-84
Smoke Index/Class: 450 or less/ "A" - Class 1 15 ASTM E-84
INSULATION LAYERS
Aluminum Foil
polyethylene backing
closed-cell Polyethylene foam
Aluminum Foil
Aluminum Foil
Former Vendor
All orders have been shipped, and all orders placed will begin shipping tomorrow, Friday, Aug. 20th.
We have alot of material on the way in, and plan to keep these kits cut and in stock to meet the demand of the popularity of the C4 Kits.
We have had sale threads previously, and the C4 Mad-Mat kit is a popular item for C4 owners, and we are now making this thread the official C4 Mad-Mat thread for new customers, as well as existing customers, to post their pictures, reviews, questions and comments here.
Please let us know if you have any questions.
this looks like a very nice kit, would you use this in place of the mass backing on the carpet? seems like it would cut down on weight and insulate better then the backing on the carpet?
Former Vendor
Tim
Former Vendor
INSULATION LAYERS
Aluminum Foil
Aluminum Foil
Aluminum Foil
Former Vendor
Yes, we did receive the order. You should have received confirmation of nthe payment when completed through Paypal. If you in fact did not, I would be happy to email it to you. Also, we will forward you a tracking number as soon as it ships, and you should have it this next week.
Former Vendor
INSULATION LAYERS
Aluminum Foil
Aluminum Foil
Aluminum Foil
Former Vendor
INSULATION LAYERS
Aluminum Foil
Aluminum Foil
Aluminum Foil
Former Vendor
INSULATION LAYERS
Aluminum Foil
Aluminum Foil
Aluminum Foil
Former Vendor
INSULATION LAYERS
Aluminum Foil
Aluminum Foil
Aluminum Foil
Former Vendor
INSULATION LAYERS
Aluminum Foil
Aluminum Foil
Aluminum Foil
