Drivers Window
Old Aug 22, 2010 | 07:26 PM
DM VETT's Avatar
DM VETT
Default Drivers Window
Driver window on 1990 Coupe goes down half way then front stops and back continues till it jams. If you push on front it will drop down even and then window will go on down. What could be problem and what is fix.
Old Aug 22, 2010 | 11:17 PM
C4boy's Avatar
C4boy
I'd sounds like your glass has come loose from the mount on the window regulator.
Old Aug 23, 2010 | 07:56 PM
DM VETT's Avatar
DM VETT
I can tell that the glass is still attached. It feels like the track is not going down right.
Old Aug 23, 2010 | 11:21 PM
shadowman1's Avatar
shadowman1
Replace the regulator.
To Drivers Window
