Starting Problems
Old Aug 24, 2010 | 06:31 PM
Klgrayson's Avatar
Klgrayson
Default Starting Problems
Corvette owners worse nightmare,Intermittent starting issues. So far I have replace the spark plugs,distributor cap,rotor, fuel filter,fuel pump and the fuel pump relay. Some day it will start and do that for 2 or 3 days,then it won't start just turns over and won't catch. Seems like when the car is in the cooling down stage is when it doesn't want to start. So if anyone has any advice it surely will be welcome.
Old Aug 25, 2010 | 08:26 AM
sailorsteve's Avatar
sailorsteve
You need to do some testing when the car acts up. Pull a plug wire and check for a good snappy spark while cranking. An intermittent problem like that could be any of a number of ignition issues, and this test you can do anywhere without tools.
Old Aug 25, 2010 | 08:51 AM
jimmers's Avatar
jimmers
I'd stop throwing money and parts at it until you figure out what the problem is. What's the fuel pressure when it doesn't start?
To Starting Problems
