Dash went out
Old Mar 29, 2002 | 07:51 PM
dmalhi1's Avatar
dmalhi1
Default Re: Dash went out (Sharky Guam)
Hey Jenn, not to get fresh...but...if I hit your G spot, will the lights automatically go out? Or will you just light up brighter? :lol: :lol: :lol: :lol:
:lol: getting off topic aren't we?
Old Mar 29, 2002 | 08:09 PM
Sharky Guam's Avatar
Sharky Guam
Default Re: Dash went out (dmalhi1)
Sorry! I could not resist it! :smash: :smash: :nono: :nono:
I for got that this is a family channel! :lol:
Old Mar 30, 2002 | 01:33 AM
thrills's Avatar
thrills
Moderatrix
Cruise-In IV Veteran
:lol: what's a little humor between friends :D
And to answer your question, only my husband knows the answer :crazy:
Old Mar 30, 2002 | 09:28 AM
Sharky Guam
Default Re: Dash went out (thrills)
Jenn, somehow I knew that you would say that! :smash: :smash:
Old Apr 2, 2002 | 11:19 PM
robertriley's Avatar
robertriley
Thrills, you won't believe it. I replaced my dash with one out of a 84 and it woundn't lite up. As soon as I put the car in drive, it turned on. Later that day it was out again. I used your womanly advice and went for the G spot. It work! Thanks, I wish it was always that easy.
Old Apr 4, 2002 | 10:24 AM
thrills's Avatar
thrills
Moderatrix
Default Re: Dash went out (robertriley)
Cool! I'm glad my little tidbit helped :)
Old Apr 4, 2002 | 12:35 PM
hz900's Avatar
hz900
hey since you have two instrument clusters now I am in need of one and I don't care if it works or not. Let me know if you are interested.
Old Apr 4, 2002 | 02:24 PM
robertpel9's Avatar
robertpel9
Default Re: Dash went out (hz900)
mine has the same issue. Lights go out occasional and i just push in on the bezel and it lights back on. Never smack the top. This may also work on occasion but you WILL damage your digidash eventually. I wonder how long pushing in on the bezel will work for before i have to actually make a repair.
Old Apr 7, 2002 | 04:11 PM
robertriley
hz900, I have to send mine in. When I get it back I get ahold of you before I do anything? or drop me an email in a month. chrish@mswmail.com
Old Apr 8, 2002 | 09:26 PM
jfb's Avatar
jfb
Most likely you have an unsoldered pin that carries the lamp current. There are two circuit boards in the cluster and there is a single row of pins on the front board that plug into a socket on the rear board. The pin closest to the center of the boards is the one that carries lamp current and the spring in the socket becomes age relaxed and increases its connection resistance which makes more heat from the lamp current and this continues until it gets hot enough to unsolder the pin on the front board. Resoldering is not a fix, it will just occur again. But, you can solder a small piece of insulated hookup wire between the pin and socket and you will never have this problem again.
You can go to the following site for info on removing your cluster circuit boards: http://www.batee@umr.edu
Old Apr 8, 2002 | 10:17 PM
MagRed_04's Avatar
MagRed_04
Default Re: Dash went out (jfb)
When mine did that, it blew the fog lamp fuse... Replaced the fuse and it was good to go!
JK
