Bleeding the clutch fluid
Old Aug 28, 2010 | 02:55 PM
skeetdaddy's Avatar
skeetdaddy
Default Bleeding the clutch fluid
It is time to change the clutch fluid in my 93 6 spd........I plan to do it on my lift and wondered if anyone has any helpful suggestions....Thanks for your time......
Old Aug 28, 2010 | 03:18 PM
STL94LT1's Avatar
STL94LT1
The only way I could get a correct bleed on my 94 was to remove the slave from the bellhousing and rotate the bleeder valve upward.
Old Aug 28, 2010 | 03:48 PM
beadist's Avatar
beadist
St. Jude Donor '10-'11
Quite a few people on here use this method. Take a look.
http://www.rangeracceleration.com/Clutch_Care.html
To Bleeding the clutch fluid
