I've posted on here a couple times in the past and had great feedback. Concerning an LT engine, were there any real problems to speak of that these engines had? Is there any years to stay away from? I have an older pickup truck that I would like to put a complete Corvette pullout in. I had wanted an LS series, but the lower cost of an LT is turning my head in that direction.
Optispark is the one real problem of an lt1. I love my vette and its an lt1 but you are buying a new engine for a truck and if your budget will swing it get the ls motor.
The only weakness of the LT1 is the aforementioned opti spark (the distirbutor of the LT1). The LS1 is a bit stronger horsepower-wise. The LT1 is basically a classic Chevy 350 small block. The LS series motors are performance oriented and have only been in the 'vette or F-body cars. The 350 has been in just about every GM product in the last 50 years save economy cars.
The optispark itself isn't bad, it's just in a horrible location. They put it below and behind the water pump. So when the WP fails (which is inevitable in every car), it drips out of the weephole and onto the optispark and that's all she wrote.
The optispark and distributor by themselves are about $600-700 in parts. It would be a VERY easy job with the engine out of the car. Like a 1 hour job or less. In the car, it can be a full day job depending on the tools you have or if the balancer pulley is frozen/rusted onto the hub.
To be honest with you, I don't know if I have ever heard of an opti going out that wasn't related to the waterpump bearings leaking. Probably 99 out of 100 opti failures are a result of the WP. I could be wrong on that though.
We basically pay for our yearly rent and employment expenses selling optisparks. They go on everyone's car with enough time. I've got a preservation thread you can read if you want to keep your unit kicking for a little bit longer.
From: The reason time exists is so everything doesn't happen at once
As mentioned, the optispark is the only real weak point in the LTx engines. If the LT1 you're looking at has the vented 2nd generation opti (installed in 1995 & 96 Corvettes) you're better off. Also, to save the opti from a leaking WP, you can install a drain tube in the weep hole to channel coolant away from the opti. Other than that the LTx is a very stout power plant. The only other thing to be aware of is that they have a tendency to develope an oil leak at the rear of the intake manifold, While not a major problem it can be annoying.
Mine failed without a bad water pump. The seal went out that held the bearings on the opti and that was all she wrote for the bearings.
[QUOTE=Rocknrollbusdriver;1575204322]I've posted on here a couple times in the past and had great feedback. Concerning an LT engine, were there any real problems to speak of that these engines had? Is there any years to stay away from? I have an older pickup truck that I would like to put a complete Corvette pullout in. I had wanted an LS series, but the lower cost of an LT is turning my head in that direction.
about a year ago i was in the same boat your in now, but i ended up with an lt engine because of the cost. i acually bought a 95 z28 with 109,000 miles on it for $1200 . pulled out the motor , trans , harness , radiatior and everything else i need for the swap and am in the process of putting it in my 80 trans am , then parted out the rest of the car and ended up with everything i needed for free . my thought was this... unless you plan i doing a lot of racing which im not ( its just gonna be my summer cruiser) by the time im done doing all the engine mods ill be around 400 horsepower which is plenty for me , and it should still get decent enough milage
You can pick up an LS for pretty cheap. They came in a lot of GM cars and trucks as the Vortec,for example the 5.3L is an LS block engine, 325 c.i. That's actually the engine I'm putting in my C4. I would look around at salvage yards for one, I found a 5.3L locally for $500 has everything except the computer with it. In the long run,I think you'll be happier with the LS.
What appeals to me about the LT1 is the classic chevy small block design and the durability of the cast iron block. The LS1 would be easier to squeeze more horsepower out of as it is easier to modify.
