Paint color?
Old Sep 4, 2010 | 08:29 PM
Robbie94's Avatar
Robbie94
5th Gear
Default Paint color?
Just got the the window sticker and build sheet from the Corvette museum and am having a hard time figuring out color. I have 94 coupe.
The window sticker says Polo Green Metallic. The build sheet says Med Green Met (45U). Paintscratch.com lists two greens...Medium Green Pearl Metallic Clearcoat 45/WA9539 and Polo Green Metallic Clearcoat 91/WA9529. Help please. Which one is it?
Old Sep 4, 2010 | 08:34 PM
KARR's Avatar
KARR
I would guess Med Green Pearl Metalic Clearcoat 45/WA9539.
45 matches your build sheet and it also states Medium Green Metalic.
JMO
Old Sep 4, 2010 | 08:35 PM
HlhnEast's Avatar
HlhnEast
Try http://www.corvettepaintcodes.com/. They have different manufacturers codes there, you might have some luck with it.
Old Sep 4, 2010 | 08:58 PM
Robbie94's Avatar
Robbie94
5th Gear
http://www.corvettepaintcodes.com/ lists only 10 colors for 1994 corvettes and as do the specifications, for 94 corvettes, found in several locations. Only one green listed - Polo green with a 45 number.
So I must assume Polo Green is med green metallic?
Old Sep 4, 2010 | 09:19 PM
Jimbo 89's Avatar
Jimbo 89
Not sure about that one. I had a 93 Polo Green Vette, and it was a very DARK green.
I think med green met is a totally diff color, much lighter. just my .02
Old Sep 5, 2010 | 12:00 AM
lushdrunk's Avatar
lushdrunk
1994 "Polo green" is OEM code 45/WA9539 (PPG 4301)
For some reason very few of the corvette color names match the OEM name. Ive yet to figure out why GM felt the need to call one color by two names. Example: Corvette's "Admiral Blue" is relay called "Dark Cloisonne Metallic"
In this case the "Medium green ploy" is the corvette's "polo green" and the other code of 91/WA9529 you posted, is not even a corvette code. 1994 GM oem "91" is call "Plumb ploy" (purple metallic, But not corvette purple metallic) and the code "WA9529" does not exist for GM 1994.
This kind of poor record keeping is why you should never order paint from a on line reseller. You should have the paint mixed local so it can be compared to the original color before purchasing to insure a correct match. Also a Paint suppler can add age to the touch up paint so it will blend better.
Here is the PPG chip chart for GM 1994. The correct color for "Polo green" is circled in red for you.
Old Sep 5, 2010 | 12:15 AM
Robbie94's Avatar
Robbie94
5th Gear
Thanks..that clears up the paint issue for me.
To Paint color?
