I am 70 miles from home. It Labor Day, so I'm hoping I might get a reply or suggestion.
My 1988 is making a noise I've never heard. It's a manual transmission. If I'm in nuetral and put it into 1st or any gear including reverse, there is a high pitch almost scretching sound that doesn't sound too good. If I'm in nuetral, the nose is gone.
Any ideas? Should I drive home 70 miles with this nasty noise?
Sounds like a throwout bearing. Does it make the noise with the clutch engaged (up) or disengaged (down)?
[edit] Noises of this nature are usually one of two things....input shaft bearing in the transmission, or throwout bearing in the clutch. One usually present with clutch engaged and the other with it disengaged.
Is the noise with the clutch in or out? Is the noise comig from the transmission? Does it change with speed? You may want to post this in the technical section.
Agreed
Let us know if the noise is associate with the Clutch use.
If the noise start/stops when you first are using the clutch...it could be TO bearing.
If you press the clutch down all the way.....the noise stops....then when you start to release the pedal the squeal comes.....It could be the Pilot Bearing.
Both answers mean the same thing....you'll have to pull the tranny and clutch out.
I forgot to answer one of your original queries.....That's kind of a loaded question without us actually hearing the noise in question. A dying throwout bearing will really only affect operation when using the clutch....unless it seizes completely, then it can tear things up. A pilot bushing can tear up the input shaft....so many variables.
If it were me, I'd drive it home unless it got a lot worse in a big hurry. Then again, I do my own wrenching, and can usually tell when something serious is about to happen.....I don't know what your particular skill level is on this. If you aren't comfortable, or are scared of doing more damage, flatbed it home. Also....are we talking 70 miles with several towns in between.....or like we have out here, 70 miles of absolutely nothing but rattlesnakes?
If it was the input shaft bearing, it would make the
noise any time the clutch pedal was up, including
neutral. Since it doesn't make the noise in neutral, it's
not the input shaft bearing.
And were are you at? Maybe somebody can help. (I'm
in Morgan Hill, which is right at 70 miles from Concord).
Friz is saying don't get stranded in the middle of nowhere. The flip side of emptiness is less use of the clutch. Depending on what it is, it MIGHT not be as bad to get on the Interstate in cruising gear and stay there until almost home, versus going through numerous little towns with stop signs, traffic lights, and other reasons to shift.
If it starts to make the noise as soon as you begin pressing the clutch pedal and feel resistance, then its likely the throwout bearing. The TOB touches the pressureplate as soon as you begin to press the pedal, and continues doing so until you let all the way off the pedal.
If it only makes the noise with the pedal mostly fully depressed, it's more likely the pilot bearing. The pilot bearing is only "in use" once the pressure plate has released the clutch disc...which happens near the bottom of the pedal stroke. Once the pedal begins to travel upward again, the pressureplate clamps on the disc again, and the pilot bearing becomes inactive once again.
Also, it is possible to drive a manual trans car without using the clutch to shift, by rev matching and "feeling" the shifter into the gate each time gently. It's not a smooth ride nor is it the healthiest thing for the trans but you can do it with no lasting side effects if you need to.
Also, it's the end of Labor Day weekend. Even the
freeways are going to require a lot of shifting. If you
are going to limp it home, I'd find a place to hole up
that has AC and cold liquids until late this evening.
Maybe it's time to see a movie.
(nonNorCal folks: It's hot today. I saw 101F coming
back from the grocery store a bit ago).
I restarted the car a few hours ago. The scretching noise only appears when the clutch is engaged. The cars seems to run fine. Every gear works smoothly and the car seems to drive well. Im going to take the car into my tranny specialist in town. I would imagine the TO bearing is probably 22 years old.
Thanks again for all your advise. Wish me luck. All 70 miles are on the freeway, so not too much shifting of gears.
Made it home this AM no problemo. Left at 5 AM to make it to work. There was virtually no noise ever while driving home, waiting at stop lights, engaging or disengaging the clutch, cruising speeds-nada. Very odd.
The night I heard the noise, my girlfriend heard it and said "WTF is that? Is your car okay?". I still have no idea what that noise was but it seemed to be directly in front of me and made a loud rythmic sctretching noise which leaves me to beleave its clutch/tranny juction issue. The car has never made that noise before and only did once I pulled up to my lady's house and put the car in nuetral. I have very little tools or diagnosis knowledge, but do have an excellent transmission mechanic.
Just as a suggestion, anyone in Contra Costa County know of a good transmission shop for a 1988 Vette?
