I love how the stock one's work and look while they are closed but mine's acting weired the right headlight open and close's fine but the left one after turning on the headlight it makes ticking sounds and you can hear the motor is still working after the headlights is turned on then it shut off after like 5-10 seconds the same thing goes while they are closed so Im thinking of saving some weight and go with custom headlights anyone have any pictures of custom headlights?
If you are talking about non pop up headlights they are both expensive $1,100.00 and hard to find. Breathless is the least expensive but have been on back order for at least 4 months.
You'd save a lot of time and money by just fixing the headlights.
It's usually the three bushings or motors that need replacing but, it's a lot easier than trying to fab up the non pop ups which IMO do not looks as good as the originals.
Nothing looks cooler than seeing the headlights flip over.
the problem is I will go with turbo set up soon and I want to get rid off everything to save weights and do custom air vents to help keep the temp down
Yes. No joke there. Especially in the world of motorcycle racing, one of the first places to start decreasing lap times is to drop some poundage (from yourself)
Every 100 pounds ends up being about .1 second (in a strait line). Both headlights and a diet...say 30 to 40 pounds. Thats pretty significant. ESPECIALLY if you're making a purpose built car for racing.
Every pound counts when aiming for speed
Reason: increasing lap times was meant to say decreasing
