Blower motor crazy?
Old Sep 7, 2010 | 03:07 PM
rickwhoo's Avatar
rickwhoo
Default Blower motor crazy?
Driving this afternoon the ac blower started acting crazy, it is blowing on and off for no reason. Sometimes it shuts off completely and sometimes the speed goes up and down. Nothing loose with wireing that I can see. Could make it change speeds while sitting in gear tapping on the gas pedal. Any ideas? 93 Coupe LT1
Old Sep 9, 2010 | 12:44 AM
jfb's Avatar
jfb
The blower motor is a d.c. motor with brushes and most likely the brushes are worn out and barely making connection to the commutator causing the motor to run intermittently. Bumping the accelerator causes the car to shake and the motor too which bumps the brushes into contact with the commutator. Unplug the motor and connect 12v to it and see if the motor will run continuously or intermittently. If intermittent, replace the motor. You can buy replacement motor at any auto parts store. If motor runs continuously, then you likely have a poor connection to the motor or the speed control for the motor is defective.
Old Sep 9, 2010 | 02:44 AM
Guinea Jay's Avatar
Guinea Jay
The blower motor in my '98 Grand Prix has had a mind of its own for years. I took it out and cleaned it up, had some corrosion from a leak. It always works when I turn it on but it randomly blows air into the car any time it wants. I blamed the climate control but it seems to work otherwise. Maybe its a GM gremlin.
Old Sep 9, 2010 | 02:52 AM
rodj's Avatar
rodj
When the key is off?
if so the Blower Control Module is faulty; is mounted in A/c ducting underhood
Old Sep 9, 2010 | 02:53 AM
Guinea Jay's Avatar
Guinea Jay
By the way if anyone has an AMC Gremlin, yes I want it. Put a cover on it and store it. I don't have any money for it now.
Old Sep 9, 2010 | 01:06 PM
SunCr's Avatar
SunCr
What everyone else says - but these Blowers can suck a lot of amps as they age and the harness terminals are crimped to the power supply - so make sure there isn't a loose connection that's opening/closing or dropping volts. Usually you'll see discoloration on the power wire and the weatherpak will have to come apart to solder up a decent connection. Try wriggling the connector/wiring around and holding it on the Blower Motor first. If it corrects the problem you'll know what to fix.
To Blower motor crazy?
