Blowing smoke
Old Sep 9, 2010 | 03:19 PM
ehengeve's Avatar
ehengeve
Default Blowing smoke
1991 c4 automatic 94K miles, will start to blow smoke at around 85 MPH (stops after dropping down below 75 MPH). I know the rear main seal & lower intake are starting to leak (winter project). Was wondering if this is a sigh of other issues (valves, seals, rings). Any ideas?
Old Sep 9, 2010 | 10:20 PM
Riks40th's Avatar
Riks40th
From: St. Louis, Mo......... 1993 Torch Red w/White Interior...2006-07 Bloomington Gold 2005-ZR1/C4 Gathering, 2001-2012 Funfest
What color is the smoke?
Rik
Old Sep 10, 2010 | 12:07 AM
Jay Axson's Avatar
Jay Axson
White smoke is water getting into the combustion chamber and creating steam. Blackish/Blue smoke is oil buring.
If Blackish / Blue it could be valve seals and/or guides. It could be rings. Do a compresion test and see what your dealing with.
If whitish, it's most likly a head gasket or worse case cracked cylinder wall.
But verify it is coming out of your exhaust by having someone follow you. If it just coming out from under the car, then it could be your leak hittinig the exhaust or something like that.
Old Sep 10, 2010 | 10:37 AM
CMYC4GO's Avatar
CMYC4GO
What do your tail pipes look like? Are they oily or wet?
Old Sep 10, 2010 | 12:38 PM
aklim's Avatar
aklim
What does your oil look like Golden or Black? If it looks like Chocolate Milk Shake, you might have other issues like a Head Gasket leak. If you run a compression test, you will know whether it is leaking in the cylinders or whether it is valve guides.
Old Sep 10, 2010 | 03:10 PM
coady485's Avatar
coady485
Cruising
Check your coolant level, If it is coolant it will have a sweet smell coming out the exhaust.
Old Sep 10, 2010 | 07:01 PM
ehengeve's Avatar
ehengeve
I would say the smoke is a blue gray. Need to find anothert Vette owner to follow me and confirm the color of smoke. Thanks for all the advise
Old Sep 11, 2010 | 12:54 PM
CMYC4GO's Avatar
CMYC4GO
So a guy driving a Ford pickup or a Dodge, or whatever make vehicle you can think of isn't qualified to follow you to check out your smoke situation, eh? Only another Vette owner can decipher your problem. That's rich.
Old Sep 11, 2010 | 09:52 PM
ehengeve's Avatar
ehengeve
No comment
Old Sep 12, 2010 | 08:55 AM
aklim's Avatar
aklim
How about checking the plugs for deposits? That might give you a clue
To Blowing smoke
