Climate Control 'Off' Light
Old Sep 9, 2010 | 04:01 PM
jmgtp's Avatar
jmgtp
Default Climate Control 'Off' Light
my 1994
When my climate control system is 'off' sometimes the light is lit but more often the light is not lit. The climate control unit itself seems to work without a hitch. Is this as simple as a loose wire or bad solder joint? Or is it actually even normal? Just to be clear, the light is not flashing indicating a problem, just sometimes when the system is turned off it is lit and sometimes it is not. Does it have anything to do with the healights being on or off? Or that daylight sensing sensor in the dash?
Do the 94s have the automatic headlights that turn on when it gets dark out? I thought that is what that dash sensor is for but my lights don't turn on unless I use the headlight switch. So either it doest have that feature, its been disabled, or its broken. I guess what I am asking is what is the purpose of that sensor?
Old Sep 9, 2010 | 04:30 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Borrowed from member perfusion from another thread. It sounds to me like your contacts are going bad.
It's an easy fix.
Yep... Common problem. He needs to take the Climate Control (CC) unit out and clean the circuit board. Before you (or he) get scared at the sound of this, let me just tell you that it is EASY.
Start by removing the lid to the center console (4 bolts). Next, lift up the carpet liner inside. At the rear of the shifter trim plate, there will be 2 bolts that hold the back down. A third is under the cupholder/ashtray linter. With those three out, the shifter trim plate should easily lift up and away. Just position it to the side and remove the two (identical to the previous 3) bolts at the bottom of the radio/CC trim plate. Next, remove the central A/C vent (2 Torx screws). When that's done, you'll see a third Torx screw that's holding the top of the radio/CC trim piece in that needs to be revomed. After that trim piece is off, you'll notice the two bolts holding the CC unit in place - remove them. The unit will now slide straight out, and you can unplug it from the wiring harness in the rear.
Take the CC unit inside to work on it. There will be 6 *small* bolts that need to come out - 4mm or 4.5mm, if I remember correctly. One tip I can give you is this - when you've got all 6 removed (two on the back surface, and 4 around the perimeter), point the face of the CC unit towards the ground while separating the two halves - you don't want the individual buttons to fall all over the place. With that complete, you will be able to remove the internals. There will be 2 circuit boards joined like a "T". They simply pull apart. Set the larger of the two aside. Then CAREFULLY remove the 4 lightbulbs (will look like grey plastic plugs from the back) with a flathead screwdriver - they should take about a 1/4 turn counterclockwise to "unlock." After they're out, flip the board over and proceed with the cleaning.
All I do is *lightly* go over the contact points (you'll be able to tell what I'm talking about when you have it apart) with a soft pencil eraser, and then give it a good wipe with some Isopropyl Alcohol pads. After it's dry, I re-assemble and head back to the car. Plug it in to the wiring harness for a test - it should work as new!
Re-assemble all other trim pieces, etc. in the order they were removed. Shouldn't take more than an hour...maybe a tick more depending on how careful you are. It really *IS* an easy job, though, so take your time and all will be fine.
Hope this helps! I've done it twice on my 96 with no problems (most recently over this past weekend). It sure beats a new unit at dealer prices (around $375, I think)!!!!!
The sensor on your dash is for the climate control IIRC
Old Sep 9, 2010 | 04:32 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Originally Posted by jmgtp
my 1994
The sensor your asking about is a Sun Load sensor, used by the climate control system.
Unless your C4 is an export model, it does not have automatic headlights. Some of the later year "export" C4's did, but I don't know exactly what year that started.
Now, for your first question about the "off" light being lit sometimes and others not.
If I am understanding your question correctly, it could be that the buttons are not making contact as they should.
See if the information in this thread helps.
http://forums.corvetteforum.com/c4-g...on-repair.html
Old Sep 10, 2010 | 08:37 AM
jmgtp's Avatar
jmgtp
Thanks for the tips guys!
Sounds like a simple lazy Sunday afternoon project.
Old Sep 10, 2010 | 08:40 AM
RetiredSFC 97
took me an hour to repair mine, been perfect ever since.
Old Sep 10, 2010 | 09:45 PM
UNCLEBILL's Avatar
UNCLEBILL
GOOD info..mine just started acting up tonite when I came home from a cruise nite. This post couldnt have been posted at a better time.
To Climate Control 'Off' Light
