Wheel Alignment....Hmmmmmm
They put the car on the rack and hooked it all up and yes it is out but they can not adjust it properly because they do not have the upper A-arm shims to adjust the camber on the front......I thought this was odd but now after looking for these things for 2 days now I understand!!!
I looked on the internet with no luck..ecklers has shims but they do not
look like what is on the car ( I am a bit **** ) I called the local Chevrolet dealer and they do not have them ( they usually have everything)
http://www.ecklers.com/corvette-cont...1963-1996.html
I took one off of the car temporarily here is what it looks like. Does anyone know where I can get a set in assorted sizes?? Thanks In Advance!!!!!!
http://www.google.com/products?hl=en...ed=0CDkQrQQwAg
Also, I would doubt the competency of a shop that does not have these ... they're pretty common, every shop I've ever been to has had them.
This is one reason why you never go to a Firestone store for work. They are feeding you a total line of
A good 4-wheel alignment for a Corvette or any other car that requires a 4-wheel alignment shouldn't be more than $60 to $75. Takes about 45 minutes to do it right. Watch out for stores that do "toe and go" alignment. They simply set toe-in and charge you for a full 4-way alignment. A shop that has a AAA sign posted should be a good deal.
Did this shop know enough to align the rear wheels too? No shims needed for the back end; just adjustments with a wrench.
Check this out if you're interested: http://www.davidfarmerstuff.com/align.pdf
**** is (ask how i know) when you do your own alignment to be sure it is 'dead on', temporarily using those 'horse sith, oops 'horse shoe' shims, then pull each shim stack out, measure and machine a 6061-T651 alum spacer same height as the shim stack to replace the 'pile', but with a center hole (vs slot) for final install...h/s shims have been known to fall out in flight.
Thanks for all the comments. I have found what I needed at the local KOI parts store. Except that I have to make the slot bigger to be able to slide them over the bolts....It is just a good thing that I am a toolmaker!!!!!
I will take my car back there...to be honest it may be partially my fault. I had stopped in to that shop on a Sunday to check out the shop. The person that made the appointment should have told me to have their
master mechanic do the alignment...I could tell that this person did not know too much about cars.....When I got there for my appointment the person at the counter looked surprised that I was bringing in a Corvette. After they realised what a job it was they recomended that I bring it back when their expert was working (next saturday).
They were pretty honest with me so I will let their expert work on it. I always have a before and after print out made when I have any of my cars done. Atleast this way I can watch the tech work and ask any questions that I have....If I had it done at the dealer I would have to
leave it over night and I would not be able to watch it being done...I was assured that their expert is very good at his job.
Thanks everyone for your input
Aligning the front end is no different than any other car that uses upper and lower control arms and shims for adjusting caster and camber. That design has been around since the 50's.Adjusting the rear end is not a lot different than other cars with an independent rear suspension.
Most shops use a computer-controlled alignment system to get alignments right. All the specs are in the computer and displayed on a monitor for the tech to see.
Take the shims back for a refund. There is no way that you should have to provide your own shims for an alignment job.
And to repeat, never ever go to a Firestone store for work. Find a reputable auto repair facility.
