FInding Option Codes
Old Sep 11, 2010 | 05:13 PM
Jamo11's Avatar
Jamo11
Default FInding Option Codes
Is there a sticker on a C4 or C5 that lists the option codes on the vehicle? WHere is it located?
Is there a website that you can enter the vin# and find the option codes for a specific vehicle?
Old Sep 11, 2010 | 06:17 PM
John A. Marker's Avatar
John A. Marker
Options codes or build sheet is often under the center counsel lid or on the lid of storage unit behind front seats.
Old Sep 11, 2010 | 07:09 PM
socalman's Avatar
socalman
St. Jude Donor '10
Early C5 coupe is under the left side storage lid, later is in glove. C4 late is underside center console. Build sheets are stashed in the cars, on C5 inside the front bumper support (never get to it unless you're doing major teardown.
Try this site- put your vin in, tells you what options were on your car
http://www.compnine.com/vid.php
Old Sep 11, 2010 | 07:46 PM
Jamo11's Avatar
Jamo11
You know, it's interesting. I went to thesite and put in the option code for this vin#, 1G1YY22G2X5125976. THis is the 1999 w/60,000. The site came back with the option sheet with every option marked and it said that:
There are 1 1999 CORVETTE 2 DR vehicles (0.006%) matching your exact options list. There are 1 (0.006%) with at least as many options.
THat's strange. It says this is the only COrvette with every option. It even includes both G90 and G92, whatever that means. Here is the list that it says this car is the only one that has all of them:
RPO Description Matches Compare
UN0 RADIO,AM/FM,STEREO,SEEK/SCAN,COMPACT DISC,AUTO TONE,CLOCK,ETR STEREO W/CD PLAYER(UN0)
11,076
UV7 ANTENNA, RR WINDOW, RADIO ANTENNA,RR WDO(UV7)
18,084
UZ6 SPEAKER SYSTEM 6, QUAD FRT DR MTD, DUAL QTR MTD 6 SPEAKER SYSTEM(UZ6)
18,084
U52 CLUSTER,INSTRUMENT(ELECTRONIC) ELEK GA CSTR(U52)
18,084
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
11,870
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
16,417
XGG TIRE FRONT P245/45ZR17 BW TL SBR HW4 EMT TIRE(XGG)
17,763
YGH TIRE REAR P275/40ZR18 BW TL HW4 SBR EMT TIRE(YGH)
17,763
1SA PACKAGE-OPTION 01 (1SA)
16,404
13U EXTERIOR COLOR,LIGHT SILVER MET (13U)
EXTERIOR COLOR,PRIMARY (13U)
2,321
92I INTERIOR TRIM SHALE/PEWTER (92I)
3,415
923 TRIM COMBINATION LEATHER, SHALE/PEWTER (923)
3,415
AG2 ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL MULTI-DIRECTIONAL P/SEAT ADJR(AG2)
ADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER 6-WAY PWR P/SEAT ADJR(AG2)
16,431
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE PASS SI INFL RST SYS(AK5)
RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
18,082
AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9)
14,708
BGR Unk. 18,082
B34 COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34)
17,765
CF7 ROOF,SUN,REMOVABLE,NON-TRANSPARENT REMOVABLE SUNROOF(CF7)
6,538
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
2,880
DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
15,947
DL8 MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC,DEFOG ELEC R/CON HTD O/S MIR(DL8)
18,082
D42 COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42)
15,673
FE1 SUSPENSION SYSTEM,SOFT RIDE SOFT RIDE SUSP(FE1)
14,273
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
11,147
G90 AXLE REAR 3.15 RATIO 3.15R(G90)
9,116
G92 AXLE,REAR,PERFORMANCE RATIO(MERCHANDISING OPTION) PERFORMANCE R/AXL RATIO(G92)
9,116
IL3 TRIM,INTERIOR DESIGN (IL3)
14,707
JL9 BRAKE SYSTEM,POWER,FRONT AND REAR DISC,ANTILOCK FRT & RR DISC ANTILOCK BRK(JL9)
18,082
K63 GENERATOR 110 AMP 110 AMP GEN(K63)
18,082
LS1 ENGINE GAS, 8 CYL, 5.7L, SFI, ALUMINUM ENGINE 5.7G(LS1)
18,082
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHAN DISING OPTION) A/TRANS PROVISIONS(MX0)
12,410
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
12,410
NF2 EMISSION SYSTEM,FEDERAL,TIER 1 FED EMIS SYS(NF2)
11,225
NK4 STEERING WHEEL,SPORT,LEATHER SPORT WHL(NK4)
STEERING WHEEL,SPORT,LEATHER WRAPPED LEATHER WRAPPED SPORT STRG WHL(NK4)
18,082
QD4 WHEEL 17 X 8.5 FRT & 18 X 9.5 RR, ALUM, STYLED STYLED AL WHL(QD4)
15,864
R9Z Unk. 5,389
T96 LAMP,FRONT FOG FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH TOURING YP6) FRT FOG LP(T96)
17,130
Old Sep 11, 2010 | 08:05 PM
socalman's Avatar
socalman
St. Jude Donor '10
11,076
18,084
18,084
18,084
11,870
16,417
17,763
17,763
16,404
2,321
3,415
3,415
16,431
18,082
14,708
BGR Unk. 18,082
17,765
6,538
2,880
15,947
18,082
15,673
14,273
11,147
9,116
9,116
14,707
18,082
18,082
18,082
12,410
12,410
11,225
18,082
15,864
R9Z Unk. 5,389
17,130
You can ignore the "1 of " comment. There are other codes in your car not shown as 'checkable' options ie. Day and week of year that a Silver Coupe was painted- for example.
As you can see, there were 18,084 auto coupes for that year. Most cars had the same options (which were actually standard with the 1SA option, so sometimes the options are redundant to each other. Another option was actually a delete- ie. the manual AC system vs the Auto system. Most cars had the 'upper' auto system, with only 2000 having the manual, as this 99' shows.
Old Sep 11, 2010 | 09:25 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
G92 tells you that the car has a "Performance" rear axle ratio. The G90 tells you what the ratio is.
Old Sep 12, 2010 | 07:49 AM
HlhnEast's Avatar
HlhnEast
Lotsa folks get excited when they see this site and see "one of". Like is mentioned, it may be the only one made that day or something else minor but no, your car isnt rare. Dam, there went the kids college money
Old Sep 12, 2010 | 10:20 AM
socalman's Avatar
socalman
St. Jude Donor '10
I did run this report on my car, and just doing the percentages of each major option (upscale options only), did come back at around 1 of 15- 1 of 4 sold in Cali (due to Cal Emissions). Still not rare, but was fun.
Old Sep 15, 2010 | 02:30 PM
anciano's Avatar
anciano
That was interesting...I have ONE OF A KIND, too!
It seems that only 1660 of the 5,395 convertibles produced in '94 came with the 2.59 axle ratio. Hmmm....I thought it was more or less standard.
Does anyone know of a site which has MSRP prices for the models and options for various years? I'd be interested to know what mine cost back then. I don't even know if the convertible was an extra-cost option or cheaper than the coupe in '94.
Old Sep 15, 2010 | 02:43 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
The Corvette Museum has exactly what your looking for.
You can get a build sheet and copy of the original window sticker.
Link: https://store.corvettemuseum.com/ser...buildsheet.asp
Old Sep 15, 2010 | 03:42 PM
Jamo11's Avatar
Jamo11
Originally Posted by socalman
... C4 late is underside center console. ...]
Do you mean underside center console top, or you have to take the center counsol out and look underside it?
And what about the earlier C4s?
Old Sep 15, 2010 | 04:11 PM
RollaMo-LT4
Well, the '96 models have the option code sticker located in the storage compartment behind the passenger seat.
Lift the lid, and you'll see the sticker.
Some other years they were located under the console lid.
You shouldn't have to take out any parts to find it.
If it's not easily seen, then it's possible the lid has been replaced.
In that case, the website socalman listed will get you pretty close.
But be advised, they don't have all C4's listed.
If you already own the car and are curious as to what options it was built with and where it was shipped, the museum site I listed above it the best place to start.
But since that information isn't free, you probably wouldn't want to use that if your just shopping.
Old Sep 15, 2010 | 04:26 PM
socalman's Avatar
socalman
St. Jude Donor '10
GU92 was the performance upgrade for the rear axle, and for auto verts, meant a 2.79? axle. Looks like 2/3 of them went out of the factory with the perf axle for 94.
Verts retailed for $42k, coupes $36- quite a bit more. Same as now.
http://www.rogerscorvette.com/specs/94.htm
Old Sep 15, 2010 | 05:50 PM
Keystring's Avatar
Keystring
It says mine doesn't exist..
Old Sep 15, 2010 | 06:18 PM
RollaMo-LT4
See above. That site is just some 3rd party site. Nothing official from GM.
So, not every VIN is going to show up.
So, see post #10 above. The museum should have your car listed.
Old Sep 15, 2010 | 08:58 PM
socalman's Avatar
socalman
St. Jude Donor '10
It seems to be pretty good from 90 up- 80s are hit and miss. They are dead nuts on for my 2 cars, so it seems when they got it, they got it right.
Old Sep 16, 2010 | 09:34 PM
RonRock's Avatar
RonRock
Cool find. I just ran my VIN and it came up with the correct RPO's for my 95.
Old Sep 17, 2010 | 08:25 AM
anciano's Avatar
anciano
That pricing guide is a shocker. I just looked up my car's MSRP with the options it has and it came to a tick over $44K. Add delivery, tax, title, etc. and somebody must have paid around 50 large for it new -- in 1994!
In view of that I like my purchase better than ever. But that level of depreciation gives new meaning to "precipitous." Almost 90% in only 16 years! I sure hope it slows down now.
To FInding Option Codes
