My automatic climate control is beginning to make me feel like a henpecked husband -- you know, always being told what you want and what's good for you instead of being able to make your own decisions. The owner's manual seems to indicate that there is a setting that allows you to admit outside air without any automatic temperature modification, but I'll be damned if I can find it. The manual says to use the upper vent button for outside air ventilation, but it also says to adjust the temperature to a "comfortable" setting.
HELLO? I don't want "comfortable" -- I want outside ambient temperature, whatever it may be. Am I correct in assuming that in order to get outside air that is neither cooled or warmed by this electronic dictator I have to accurately divine the outside temp and use exactly that temp setting? It certainly seems that at some point the thing takes over control and decides what I want even when I'm not using the auto function button.
Is this thing a descendant of HAL from "2001: A Space Odyssey"? "I'm doing this for your own good, Dave...."
The button that indicates the upper vents is the outside air. It's the third or fourth button maybe two to the right of the recirculation button. You don't need to adjust the temp but you may want to adjust the fan speed to your liking.
But you may need to lower the temp so you don't get heat, I'm not sure now.
I know what you mean. It took me a while to figure that thing out too. If you push the button for dash air only, you get outside air with no A/C but you have to adjust the temp to something below outside air temp or it will add heat to it. [ A Vette in Texas has enough hot air in and around it already!] The button with vent and under dash is an A/C controlled position. I do love the Auto button though when on the road. Just set the temp and drive from desert to mountain and the temp stays the same. Windows down and dash vent driving are usually reserved for cooler days here in Texas.
The only setting that will not run the a/c compressor is the "Vent" setting.
This is the button with the arrow pointing at the mans head.
All other settings will run the A/C compressor if/when the temp setting calls for it.
In the vent setting the temp will be whatever the outside air temp is. You can adjust the temp to warm the air up if needed, but it will never be cooler than ambient outside temp.
And to disable the A/C compressor, make sure the AUTO button on the right side of the panel (surrounded by the FAN speed buttons) is not illuminated.
This way, you can manually set the blower speed and interior temp out of the vents without any AUTO CLIMATE CONTROL assistance.
So to get completely unconditioned air I need to:
1) use the "face" vent button; and
2) set the temperature as low as it will go so that the heater is not activated.
Is that right? It would be a lot better if the heater was disabled along with the a/c on that vent setting. As long as there is a fully "auto" setting available I can't see why the thing needs to make ANY decisions for me if I don't want them.
This looks like the kind of thing a marketing department dreamed up. The focus group they used probably didn't understand the apparatus, either, but liked all the buttons.
Just use the button that indicates the upper vents and then use the fan control speed buttons. It should allow outside air in, but will only allow in what the fan speed is set for. It's not like the old cars when set the outside air and it blows freely.
To be sure adjust the temp buttons so you don't kick on the heater. Adjust the temp to a temp at or below the outside temp. I don't know if you actually have to set the temp or not so just play with it and see what happens.
I seldom use mine actually but have on a few occassions.
You don't need to set the temp as low as it will go. Just set it at or below the outside air temp. Again, I don't know if you "have" to set the temp so just play with it and see what happens. I don't use it that much myself.
Yes, that is right.
It has nothing to do with being "full auto" really. You don't have a control valve to shut the water flow off from running through the heater core.
So, by setting the temp to lower than outside temp you are preventing the blend door from opening and allowing heated air to enter the system.
I guess if you want to disable the heater, you could splice a valve into the heater hose, so you could shut if completely off.
People have done that if they have a leaking heater core and they don't want to fix it.
Right, I understood that. I guess I should have mentioned that I live in Norcal and spend a lot of time in the Sierra where varying altitude can change temps 20F in a half-hours drive. I wouldn't want to be motoring happily over a high pass and find myself enveloped in hot air -- might think I'm having a male menopause hot flash.
To get outside air through the vent system, first turn auto system off then push in the upper vent air button. This gives you ambient outside air. Works great when the car has not been driven. The air passages heat up when the car is stopped after being driven, when you start driving again the vent air is hot. To correct this, operate the air conditioner a few minutes to cool the air passages than reprogram for outside air. I use the outside air position often with the top down.
