My '92 shop manuals have not arrived, and I need to remove the passenger's
door panel. I've removed every screw I can see, yet there is something that
is holding the black trim panel on (where door latch, lock, etc are located).
I've removed the two screws I found (inside near the door latch handle and
behind the light, but something is preventing me from removing the trim
panel...
There is a screw behind the sliding lock. And also a screw behind the power window switch. Here is a quick reference. Sorry it is so dark. It is the only picture of the passenger door panel I have.
** oops guess I should have read the second post. :bb
