soft gas peddle
Old Sep 24, 2010 | 09:48 AM
Blame's Avatar
Blame
Default soft gas peddle
My gas peddle is very soft. When I turn the vette on she idle like she should. But, the second I touch the gas peddle it start to idle high and will not come back down. I pop the hood to see that the TB was some what open. I close it and it back to normal Idle. But, like I said before the second you touch the gas peddle it leave the TB open again.
Can someone help me with this, and please no comment on my spelling. I really need help.
Old Sep 24, 2010 | 09:51 AM
CMYC4GO's Avatar
CMYC4GO
Sounds like a return spring problem.
Old Sep 24, 2010 | 09:54 AM
Blame's Avatar
Blame
Ok, where is the spring and if it on the TB then it can't be. The TB is new and I had the same problem with the old one.
Old Sep 24, 2010 | 10:03 AM
CMYC4GO's Avatar
CMYC4GO
If you're two for two, then it's definitely a return spring problem. Your throttle cable is spring loaded, as is your gas peddle (I think)
Old Sep 24, 2010 | 10:05 AM
Blame's Avatar
Blame
You think a new cable will help my case?
Old Sep 24, 2010 | 10:08 AM
CMYC4GO's Avatar
CMYC4GO
Probably
Old Sep 24, 2010 | 11:56 AM
Blame's Avatar
Blame
I been looking and found use TB cables. Does anyone know of a place that sell them new or like new?
To soft gas peddle
