window in convertible top
Old Sep 30, 2010 | 09:48 AM
Harvey C. Hansen's Avatar
Harvey C. Hansen
Cruising
Default window in convertible top
Is it possible to reattach, re-glue, the plastic rear window in my rag top? Top & window are still original.
Old Sep 30, 2010 | 09:55 AM
silverja's Avatar
silverja
Default Stop by a restorer
You may want to visit a local interior specialist. They may have the right products available to assist. I am not certain that any direct replacement plastic rear window exists for retail buyers. It may not be an easy fix for a first time application either. Luckily, I have a pro who can correct this issue for a reasonable price in my area.
Best of luck,
John S.
Old Sep 30, 2010 | 10:38 AM
Keystring's Avatar
Keystring
Best of luck,
John S.
I'm pretty sure the window is sewn in, so if it's loose on a corner or somewhere else then either the stitching has deteriorated or the plastic is actually torn.
A professional shop could fix it in either case much easier then you could at home.
Old Sep 30, 2010 | 05:27 PM
anciano's Avatar
anciano
I glued my glass window ('94) back in place after it was completely detached -- but of course it was originally glued in, not sewn in as yours may be.
If they are the same size I can't why why you could not find a glass window somewhere and glue it in place. Alternatively, you could cut a sheet of heavy-duty vinyl to shape and glue it in.
If you do either of these things it's easier to completely remove the top (with frame) so that you can lay the back portion on a flat surface for gluing in the window. The top can be removed in minutes by unbolting the brackets that hold the frame to the body -- don't try to remove the frame from the brackets!
Old Sep 30, 2010 | 06:33 PM
enventr's Avatar
enventr
I siliconed the glass rear window of my 95-common problem on the glass windows-I do not know about the plastic windows-I would try an interior and conv. top place to ask them
Old Sep 30, 2010 | 07:51 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Where are you located. Maybe, someone can recommend a shop
Old Oct 1, 2010 | 10:27 AM
Harvey C. Hansen
Cruising
I am on the search for a product called "Marine Goop". Was recommended by a couple of people who do interior & tops. I am located in Minnesota, so I would like to repair it before it is stored for the winter.
Old Oct 1, 2010 | 12:02 PM
anciano's Avatar
anciano
Try West Marine, online if there is no store around you. They have a lot of marine-grade sealants and adhesives. I used their store brand clear silicone sealant. It is flexible but makes a VERY strong and durable bond.
To window in convertible top
