rear axle alignment
Old Oct 2, 2010 | 04:15 PM
Harvey C. Hansen's Avatar
Harvey C. Hansen
Cruising
Default rear axle alignment
Anyone know what the caster & camber should be for the rear axle? I have a Z51 suspension. 1986 convertible.
Old Oct 2, 2010 | 06:57 PM
rodj's Avatar
rodj
http://forums.corvetteforum.com/1571261984-post19.html
Old Oct 2, 2010 | 07:54 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
No you don't.
Old Oct 3, 2010 | 10:09 AM
c4cruiser's Avatar
c4cruiser
Originally Posted by Z-07 freak
No you don't.
Z51 wasn't available in the convertibles.
For street driving, total toe at rear should be 1/8" in (1/16" per side) and 0 degrees camber. You can also go with up to a .5 negative camber.
For the front, total toe is 1/32" in, 0 degrees camber and 5-7 degrees positive caster.
If the rear is out of alignment, get a 4-wheel alignment done.
Old Oct 3, 2010 | 10:37 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Old Oct 3, 2010 | 10:58 AM
Harvey C. Hansen
Cruising
The original owner wanted it put on this car. With enough money, you can do anything. It does have the Z51 suspension.
To rear axle alignment
