darn heater core
Old Oct 4, 2010 | 01:28 PM
Blame's Avatar
Blame
Default darn heater core
Ok, I learn in a bad way to learn your heater core got a leak. I left for work at around 2 PM. I had finish my laundry and took it with me when I left. ( I hope can tell I was not at my apartment ). Well I got off from work at 11 PM. The second I got home pick up my nice clean laundry and it is all wet.
My whole passenger carpet is wet. To make this shorter I having to redo my laundry and move some tubes around.
So, what way did you learn your heater core started to leak.
Old Oct 4, 2010 | 02:03 PM
jon0108's Avatar
jon0108
My heater core sprung a leak right after i installed my brand new mass backed carpetting. I had to take out the pass. side carpet to properly clean it and to clean the floorboards. Coolant leaves a slimy coating. I did bypass the heater core before i reinstalled the cleaned carpet.
Old Oct 4, 2010 | 02:51 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
The damned Bose CDM/tuner module (passenger side hush panel) ain't no picnic, either....
Old Oct 4, 2010 | 02:59 PM
Blame's Avatar
Blame
To tell the truth that was easy for me to take out.
Old Oct 4, 2010 | 03:08 PM
onedef92's Avatar
onedef92
You'll never get it wired back in all neat and purdy like the factory did, though.
Old Oct 4, 2010 | 03:20 PM
Blame's Avatar
Blame
Step one: use zip ties
Step two: take you time.
Fact one: the people from the factory been doing this longer them me or you
Fact two: they had it easier then us.
Old Oct 4, 2010 | 03:29 PM
samsonb's Avatar
samsonb
I've read you want to be sure to get a good heater core. Some have replaced their core just for it to leak again in short order. It looks like AC Delco gets good recommendations to stick with.
Old Oct 4, 2010 | 03:36 PM
Blame's Avatar
Blame
I bypassed it and not planning on replacing it till I get the money to restore the interior of my baby. Beside I live in Florida heat not a problem here.
Old Oct 4, 2010 | 03:47 PM
Redghost's Avatar
Redghost
St. Jude Donor '10
It's a really big problem in finding it,
but, the biggest problem is repairing it.
If you have someone else do the repair, it's $$$$$$$.
If you try to do it yourself, it's one big PITA.
I wish you lots of luck.
Old Oct 4, 2010 | 03:53 PM
Blame's Avatar
Blame
Not passing that down. I need all the luck I can get my hands on.
To darn heater core
