crossfire intake question
You will get opinions varying to each end of the spectrum on this.
I finally got my stock intake off yesterday and was able to do some side-by-side comparisions with the Renegade.
The much wider base to top mounting surface is the first obvious difference and the much larger plenum area without the huge EGR hump is next.
When you turn the intake over it just makes you want to cry. The stock runner outlet is 1" by 1.375" - but the stock port in the head is slightly more than 1" wide and a full 2" tall. The port in the intake is a full 5/8" shorter than the port in the head! The Renegade is port matched to the FelPro 1205 gasket which is 1.25" by 2.09".
Worse than that is the fact that the entry for the stock runners is the SAME SIZE as the outlets! The walls of the runners are about 1/8" thick, so no matter how much you port it, there is simply no way to port the intake enough to even get close to the stock size of the port in the head. The inlets of the Renegade runners were a little more than 1.25" in width and a full 2" tall.
Bottom line is, the only way to get the stock intake to come anywhere near close to what the renegade can do would be to add a LOT of material outside the plenum area so that you can port the intake without punching through to daylight, then machining away all the stock runners and fabricating new runners to weld in place of what you cut off. The other problem with trying that is that the base of the pleunum is too high so if you built runners that are tall enough, they'd hit the top plate so you'd have to go wider instead - and you'd probably still need to machine up a short spacer (maybe a 1/4") to get more plenum volume.
Bottom line is, yes porting the stock intake is feasible if you can do it yourself and know what you're doing, HOWEVER, keep in mind that it's like a band-aid on a shark bite - sure it's better than it was, but it will never be the same as the Renegade. For all the work and expense it would take to try to get close to what the Renegade is as-produced, I can't imagine anyone wasting the time with the stock intake anymore. Plunk down your $465 and be done with it!
Basically, don't bother wasting your time porting the stock intake. It's a lot of work and does give some gains, but nothing like what the Rengade can do!
May get it running this winter if the Vette behaves & quits opening my wallet.
Yes, I dyno'd it pre-install and ran 159 rwhp and 239 ft/lbs of torque. I haven't checked the fuel pressure yet.
I'll do a post install dyno check as well after I sort out the funky problems I had after the install. The problems were unrelated to the intake.
- No good cold air. Use a moto drill and cut a hole in the air box the size of the hole in the hood. Use a good house hold weather strip around the hole to seal it when the hood closes. At WOT the CFI can't breath. This hole helps a lot.
- 1.5 roller rockers. About $180.
- I had an X-Ram but now there is Renegade - get one.
- The heads are low compression. They're about 72 CC combustion chamber. I changed to 64 CC Vortec heads. It raised the compression ratio to about 10:1.1.
- Put on 2" TBs. Stock TBs are equiv. to 450 cfm together- dismal. 2" TBs raise to about 700 cfm.
- Don't go with any higher than 65# injectors. Anymore causes plug fouling.
- 85+ fuel pump is a must. Regardless what these 'newbee' '84 guys say you need a 'constant' 14 psi at the TBs. Less than that will cause sputtering and hesitation.
My '84 dyno'd 220 rwhp, 315 rwtq and 265 hp at the flywheel. I dyno'd at 5800 rpm. I told the technician not to take it over 5800. It may have done more. It didn't flatten. I used to eat LT1 C4s with an auto and compete very well with C5 coupes with auto.
. Any problems with the roller rockers?
