Intake makeover (runners & plenum)
Old Oct 17, 2010 | 01:54 PM
RLDaily's Avatar
RLDaily
Default Intake makeover (runners & plenum)
The plenum and runners on my '90 are original and ugly after 20 years, other than polishing, powder coat or plating what can I do to make them look better?
Old Oct 17, 2010 | 02:26 PM
ch@0s's Avatar
ch@0s
You can paint or have them bead blasted.
Here is mine when I had runners, painted.
Old Oct 17, 2010 | 04:53 PM
jeffp1167's Avatar
jeffp1167
You should buy the distributor cover delete plate then the plenum would look better.
Old Oct 17, 2010 | 05:31 PM
lushdrunk's Avatar
lushdrunk
Bead blasting is the best way to make you intake look new again while keeping the OEM look.
BUT You could use an aluminum brightener to renew the look of the intake. Just remember aluminum brightener is an acid and is harmful to electric parts, wires, and rubber.
The valve covers are powder coated from the factory. (Do not bead blast them) MA motorworks sales the correct shade of silver in a rattle can to paint the valve covers.
Old Oct 17, 2010 | 10:38 PM
ch@0s's Avatar
ch@0s
I bought the TPI delete plate.
[/IMG]
Old Oct 18, 2010 | 01:42 AM
Calderone's Avatar
Calderone
ha ha ha me too ! (sr)
Old Oct 18, 2010 | 06:52 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
I recently did a make over on my TPI. I polished the TPI and I realy like it. I did it myself. Its basically sanding your parts until smooth with different grits of sandpaper. Doesnt cost that much either. I think I spent under 50 bucks for materials to do it. Post up some pics when you do your project. Good luck
Mike
Old Oct 18, 2010 | 07:39 AM
96 Vette CE's Avatar
96 Vette CE
Banned Loser
From: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
Mike
I like the edelbrock valve covers you added, looks nice.
Old Oct 18, 2010 | 07:48 AM
CorvetteMike2024
Corvette Enthusiast
Thanks, I tried to do something with my stock covers. I painted them black, didnt like it, painted them silver, didnt like it either.
Old Oct 18, 2010 | 07:56 AM
96 Vette CE
Banned Loser
I remember back in the 70's and 80's that would be the first thing i would do is to get their engine dress up kit and install it. Didn't make it go any faster(then again i didn't need to go any faster)but it sure looked pretty.
Old Oct 18, 2010 | 08:00 AM
CorvetteMike2024
Corvette Enthusiast
Well I did take the frisbee off.
Old Oct 18, 2010 | 09:33 AM
ch@0s's Avatar
ch@0s
Looks faster to me
I think mike did a great job. Those valve covers have a very classic but classy look.
Old Oct 18, 2010 | 01:10 PM
96 Vette CE
Banned Loser
Every little bit helps Mike.
Looks faster to me
Old Oct 18, 2010 | 01:25 PM
jeffp1167's Avatar
jeffp1167
probably what broke your a/c compressor bracket. My friend removed his frisbee and it did the same thing. It's there to I guess smooth compressor engagement.
Old Oct 18, 2010 | 10:20 PM
CorvetteMike2024
Corvette Enthusiast
I just took the frisbee off last week. It has been on there 21 years.
Old Oct 18, 2010 | 10:32 PM
hooked073's Avatar
hooked073
Mike car looks good
Old Oct 19, 2010 | 12:06 AM
samsonb's Avatar
samsonb
I took my frisbee off as well. Makes changing the belt a 5-10 minute job instead of an hour trying to get the belt around the frisbee and on the crank pulley as the frisbee is in the way of getting your hand down there.
Though, I noticed a few days after pulling the frisbee and putting on a new belt that the front seal on the compressor starting slinging oil on the hood. Kinda wish I left it alone.
To Intake makeover (runners & plenum)
Old Oct 19, 2010 | 12:07 AM
yaknow's Avatar
yaknow
recent powder coating, painting and valve cover replacement
Old Oct 19, 2010 | 09:31 AM
socalman's Avatar
socalman
St. Jude Donor '10
Ok, what is this frisbee thingy- pics?
Old Oct 19, 2010 | 10:14 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
It's a big, round, piece of metal that was installed on the water pump pulley of the '88-'91 Corvettes. Sorry...no pics.
