285 vs 275
Old Oct 21, 2010 | 11:54 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Default 285 vs 275
Looking at some Sumitomo tires for my 93 and I can only get the rears in 275 width. Is there any problem with that?
Old Oct 21, 2010 | 01:08 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
No, no problem at all.
You would probably have to be close enough to actually read the size on the sidewall in order to tell the difference anyway.
Old Oct 21, 2010 | 01:48 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
I'v got 285's and am going to 275's for autoxing. You really don't notice any diff.
Old Oct 21, 2010 | 02:32 PM
Redeasysport
That's what I thought thanks guys
Old Oct 21, 2010 | 02:47 PM
American Raven's Avatar
American Raven
C3 Corvette Enthusiast
The main difference is price. 285's cost a good bit more than 275's. It's not worth the difference in price.
Old Oct 21, 2010 | 03:11 PM
abecon5's Avatar
abecon5
yeah and i bet it will fair better in the snow.
unless you are upgrading to 315s you wont really feel a difference.
Old Oct 21, 2010 | 03:30 PM
1allspub's Avatar
1allspub
Something to consider though is your front tire size. That is, if you are running say 255/45/17 up front (as some later C4s do) then a 275/40/17 out back will mean that your rear tires will be over 1/3'' shorter (total diameter) than your fronts... And that may be noticeable. So if you go with 275s out back you may want to go to 245/45s up front (those two sizes are a perfect match height-wise). If, OTOH, you are already running 275s up front then nevermind... You're good.
Just be sure to do the math & keep f/r correctly proportioned & you'll be good!
Old Oct 21, 2010 | 07:18 PM
Redeasysport
Thanks Jon I was thinking about that difference between 40 & 45's but how would the narrower width cause the tire to lose height it shouldn't matter should it? If it calls for 45's up front and 40's in the back it should not make any difference on the width should it?
I asked in another thread but what rim size is the minimum to mount 275's on. In other words do I need to get new fronts to run 275's all around?
Old Oct 21, 2010 | 07:34 PM
kimmer's Avatar
kimmer
If there all 9.5's there's no problem.
Old Oct 21, 2010 | 07:35 PM
kimmer's Avatar
kimmer
Old Oct 21, 2010 | 07:39 PM
1allspub's Avatar
1allspub
the '45' in 245/45/17 is the sidewall height (aspect ratio) which means that it is 45% of the width (245) of the tire. Therefore a 245/45 will be a bit shorter than a 255/45. IOW it's relative to the width.
To 285 vs 275
