Jacking point problems 1994 coupe
Old Nov 2, 2010 | 08:37 PM
auggy's Avatar
auggy
Default Jacking point problems 1994 coupe
I need alternative jacking points for my c4 since the metal flange DOES NOT EXTEND BELOW THE FIBERGLASS. In photos I have seen on c4 jacking points show the flange below the fiberglass maybe an half a inch or so, but on my car it is even with the fiberglass. At this point I would believe the best place would be where the flange turns inward from the front tire(just behind it) or rear tire(in front of it) and is most exposed. Need help before I screw something up.
Old Nov 2, 2010 | 09:56 PM
samsonb's Avatar
samsonb
I jack the front up via the K member. I jack the rear one wheel at a time via the stock jacking location.
Old Nov 2, 2010 | 10:02 PM
Ape0r's Avatar
Ape0r
When you say fiberglass, are you referring to the chassis itself or to the body color panel below the door sills? If its the panel, you can just press that up. Just injection molded plastic, real flexible.
Old Nov 2, 2010 | 11:40 PM
CE1's Avatar
CE1
Use hockey pucks to cushion the lift points. my $.02
Old Nov 3, 2010 | 09:46 AM
auggy's Avatar
auggy
Yes, I am referring to the colored panel with the 2 arrows on it (them). The metal flange does not come below the panel, it's just even, or a pinch below. How that thin piece of metal is going to hold up the car is beyond belief. On one side , front , where the arrows are,the metal flange is cut out. It looks like someone tried to lift it ,then it bended, then someone cut it out.
Old Nov 3, 2010 | 09:51 AM
auggy's Avatar
auggy
Could you explain more about the k member. Where it is , what it looks like? Probably looks like a k
Old Nov 3, 2010 | 11:07 AM
samsonb's Avatar
samsonb
Run a search as there are a few tech articles with pics on jacking up a C4.
To Jacking point problems 1994 coupe
