Fuel pressure help!!!! Please!
Old Nov 2, 2010 | 11:22 PM
Jonathon1990vette's Avatar
Jonathon1990vette
Default Fuel pressure help!!!! Please!
Ok well i changed my fuel pump about a month ago, and had my car at the paint shop for the past two weeks. Well when i picked up the car yesterday it was going fine until i kind of got on it a little and it was cutting out just like before, before i changed the pump. I did buy it used from this forum but it is a high flow and apparently not many miles on it. Could I have done something wrong or could it just be dying. The car starts right up and is fine going 30 to 40, which is the weird thing. Im worried the strainer fell off or something or maybe something got into the fuel filter. Anyone have any ideas?
Its hard to enjoy the new paint( Ill have pics up tomorrow in the paint thread) when the car doesnt run right.
As always thanks in advance
Jon
Old Nov 2, 2010 | 11:23 PM
Jonathon1990vette
or maybe would the injectors have anything to do with it?
Old Nov 2, 2010 | 11:28 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
No worries you will figure it out. Is your check engine light on? Check fuel pressure at the fuel rail. Be careful of that pretty new paint while you are working on your car. We need more details to help you figure out whats going on,
Mike
Old Nov 2, 2010 | 11:29 PM
jimmers's Avatar
jimmers
When its cutting in and out what is the fuel pressure at? Did you replace the fuel pump because you thought it was the problem, or did you know it was the problem? Have you replaced the fuel filter lately?
Old Nov 2, 2010 | 11:33 PM
Jonathon1990vette
I guess i need to buy a fuel pressure guage. Basically it turns on fine, runs fine as long as i drive it normal(slow) up to 50 at least. But if i try to gun it, it will rev but wont go, almost like it goes into nuetral. Its not the tranny. Its not like transmission slipping. See when i first replaced it i drove it and got on it and it went fine. Somehow sitting around or something may have messed up the new one.
Old Nov 2, 2010 | 11:39 PM
Jonathon1990vette
It doesnt cut out when i rev it. I have to be driving.
Is the only way to figure it out have to be done with a guage?
Old Nov 2, 2010 | 11:43 PM
CorvetteMike2024
Corvette Enthusiast
Kind a sounds like a vacuum leak? anyone else think this? Or maybe a sensor wire? From having your car taken apart at the body shop.
Old Nov 2, 2010 | 11:44 PM
CorvetteMike2024
Corvette Enthusiast
It doesnt sound like the pump to me. Maybe also ck fuel filter.
You need a fuel pressure gauge to ck fuel pressure.
Old Nov 4, 2010 | 06:57 PM
Jonathon1990vette
I think i figured it out. I am getting air in the fuel line. Now I just have to figure out from where and how.
Old Nov 4, 2010 | 07:03 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Check back at the tank first because that's what you took off. Make sure your hoses are good and fastened securely and properly and hooked to the correct inlets.
Old Nov 4, 2010 | 07:12 PM
Jonathon1990vette
Tomorrows project lol. Working on my vette on my b day
Im thinking it could be the gasket of the fuel pump. I didnt change it. But ill check that and the lines. Wish me luck
Thanks guys
Old Nov 4, 2010 | 07:34 PM
CorvetteMike2024
Corvette Enthusiast
Thanks guys
Well good luck and Happy Birthday..
Mike
Old Nov 5, 2010 | 02:40 PM
j-wireman's Avatar
j-wireman
I would change the gasket. One other thing that is overlooked is the gasket on the gas cap. One little crack and it's done. Check it out.
Old Nov 6, 2010 | 06:18 PM
96_vette's Avatar
96_vette
Check the fuel cap O-ring and make sure the cap seals tightly. Then check fuel pressure at the fuel rail. Also check the fuel pressure regulator.
Old Nov 6, 2010 | 07:09 PM
larry00's Avatar
larry00
Change the Fuel filter first ! And you do need a fuel pressure guage to check fuel pressure . Shop around they are not pricy !
A vaccuum gage is even cheaper !
Old Nov 7, 2010 | 09:00 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When I had fuel filte issues I could stab the accelerator (in park) and see the fuel pressure spike down. The vacuum line to the FPR must be off & plugged for this test.
Old Nov 8, 2010 | 10:04 PM
Jonathon1990vette
At turn key it is mid 40 and at idle is goes down to 32 1/2... Im guessing that is to low?
And what is "The vacuum line to the FPR must be off & plugged for this test."
To Fuel pressure help!!!! Please!
Old Nov 8, 2010 | 10:08 PM
CorvetteMike2024
Corvette Enthusiast
Your FPR is located on the pass. side of the intake. Towards the back. Just in front of the distributer. It has a vaccuum line to it.
Old Nov 8, 2010 | 11:00 PM
Jonathon1990vette
Sorry im not the most savy guy with cars. I try to learn all i can. What is the fpr? Is it a vacuum? Like for air and gas? and would anyone have a picture with what it is pointed out? Sorry to keep asking stupid questions.
Old Nov 9, 2010 | 06:32 AM
CorvetteMike2024
Corvette Enthusiast
FPR is fuel pressure regulator. Its located behind the first spark plug wire on the passenger side of my motor in tthis pic. Its under the plenum, on the intake manifold. You should realy think about buying a factory shiop manual. Not one of those haynes manuals. But the red FSM
