rear hatch pops open unexpectedly-help
Old Nov 3, 2010 | 08:40 PM
jwalker260's Avatar
jwalker260
4th Gear
Default rear hatch pops open unexpectedly-help
I find my '96 hatch open at times for no reason. Occasionally the release will click continuously for no reason. I can only stop it by disconnecting the battery. Any suggestions?
I've noticed that when I find the hatch open, the doors are also unlocked.
Old Nov 3, 2010 | 08:50 PM
powerpigz-51's Avatar
powerpigz-51
Hatch switch in drivers door...mine does the same thing on occasion. Try wiggling it around to see if that is your problem. They are very cheesy plastic.
Old Nov 5, 2010 | 08:13 AM
HlhnEast's Avatar
HlhnEast
Both of my door panel switches wont return to center by themselves so I have to be careful when popping the hatch. At some point I will use some contact cleaner and/or lubricant to see if it will correct the stickiness. If that wont work, new ones are about $40-50 each. Corvette tax at its best
Old Nov 8, 2010 | 03:04 PM
85vetteguy's Avatar
85vetteguy
This has happened to me a few times while was closing my drivers door. Probably the switch in the door. Guy
Old Nov 8, 2010 | 03:11 PM
Goldcylon's Avatar
Goldcylon
Did the (Passive keyless entry) PKE light come on as well?
Old Nov 8, 2010 | 09:55 PM
Domindart's Avatar
Domindart
My PKE went crazy and I was also getting the hatch openning and the mechnism going off repeatedly... then the light (PKE) came on , on the dash... the fob wouldnt work, and trying to reset the fob via the dash programming didnt work. So... I took the PKE fuse out and now I dont use the PKE. I think its the PKE module behind the dash...
But thats a serious undertaking... taking the dash out.. so I make due w the key for now
Old Nov 9, 2010 | 12:31 AM
Wathen1955's Avatar
Wathen1955
That's what my PKE did - it went nuts and I had the module replaced that is located inside the dash. A used one was $100. I have the old one and it looks like its in good shape. I did not see any broken components, so it must be the ram chips that are bad (according to the FSM).
Old Nov 9, 2010 | 03:40 AM
Domindart's Avatar
Domindart
Did u install it urself?
Old Nov 9, 2010 | 08:43 AM
jwalker260's Avatar
jwalker260
4th Gear
I don't know. I have never seen the hatch pop open, I just find it open.
Old Nov 9, 2010 | 03:53 PM
Domindart's Avatar
Domindart
Do u have PKE on the car?
Old Nov 9, 2010 | 06:51 PM
jwalker260's Avatar
jwalker260
4th Gear
Yes, it is equipped. I removed the battery from the fob a year ago, that had no effect. Someone suggested to remove PKE fuse. Haven't had time to try that yet.
Old Nov 9, 2010 | 08:17 PM
Wathen1955's Avatar
Wathen1955
Nope. Don't have the time, and I was not comfortable ripping the top off of the dash and squeezing my big fat hand to get at it, so I had the local Chevy dealer do it for $500 installed.
My issue was with the PKE light always remaining on while the car was running. Got tired of seeing the light on all the time so I had it fixed. Do a search for my name and see the thread on my PKE issue. I was able to turn the light off by re-inserting the key after I had turned off the motor.
Old Nov 9, 2010 | 08:22 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Charlie, do you have anything on the center console that may be applying pressure on the button in there?
That happened to me before and it was a pack of bubble gum.
The post above mentions the PKE, remove the fuse and see if it happens again.
Old Nov 9, 2010 | 08:32 PM
rogerzr1's Avatar
rogerzr1
I had a problem with my hatch popping open when I was driving the car. It turned out I had a loose wire under the center console button.
Old Nov 9, 2010 | 09:28 PM
samsonb's Avatar
samsonb
Does the C4 not have a hatch release lockout with the car running? On the 3rd gens, you can't open the hatch via the hatch release button with the car running.
Old Nov 9, 2010 | 09:36 PM
rogerzr1's Avatar
rogerzr1
My 91 hatch was popping open while I was driving. It just about drove me crazy. I kept having to pull over and push it back down.
Old Nov 10, 2010 | 08:18 AM
jwalker260's Avatar
jwalker260
4th Gear
NO, I have never seen the light on.
To rear hatch pops open unexpectedly-help
