After getting my car out of Winter storage, I decided to take the car for a small run to warm everything up and make sure all joints and bearing are OK. The coolant temp got to 230 and the O/D light came on. BUT.....no overdrive. Cpuld this be a faulty relay or a bum O/D unit???? :cry How can I check the relay to see if it's at fault?
Check the oil, not the regular 4 speed tranny oil, but the OD unit oil. I just went through a costly OD unit replacement because i didnt think to check it after storing the car.Needless to say, it was leaking...
Good luck with that and hopefully it will be the relay, if though you need a OD unit , the people i got mine from are modifying it up to 88 specs so it wont run as hot as the 86's. I gotta admit , it feels like a different car ;)
....the people i got mine from are modifying it up to 88 specs so it wont run as hot as the 86's. I gotta admit , it feels like a different car ;)
For what it is worth, the 86-88 cars had identical internals for the OD unit. There was only one small difference, and I cannot remember it for the life of me right now. Also the ECM O/D programs from 86-88 only had one difference, and that was a couple of different RPM requirements for the logic.
ooohhh no! Keep us posted, but I'll tell you that a good friend and very knowledgable vette owner told me that if the light turns on but the unit does not actually engage, then it's the unit :( I've had some problems with mine and changing the ATF in the OD unit always helps. When this is the problem though, the whole thing doesn't turn on (neither light nor unit) when it's suposed to. It would turn on later, at any given time.
Well, if the OD light comes on then the ECM and relay are working fine since the light is powered off of the relay. To test the solenoid in the OD apply 12 v to connector F on the ALDL. This applies 12 v directly to the OD solenoid. The OD light should come on and you should hear a thunk under the car. If you hear this, then all the electricals check out. If not, check the electrical connection to the unit. Is it making good contact? Is the wire going into the OD providing 12v when the OD light is on? Maybe after sitting the connector needs a shot of WD40 and some scotchbrite.
If the OD solenoid is working, then next recommend you check fluid level in the OD - stick a finger in the filler opening. Low fluid will keep it from operating. Fluid/filter should be changed every 10K miles anyway.
