Headlight Issue
Old Nov 25, 2010 | 05:12 PM
PJohnsonATX's Avatar
PJohnsonATX
Default Headlight Issue
Stepdad is having this issue with one of his headlights. Same behavior raising and lowering. Snapped a quick video.
http://www.youtube.com/watch?v=l4rt475yEmo
Any ideas? We found a missing c-clip on one of the hinge joints which is causing excessive play in the movement. I suspect this to be the cause.
Old Nov 25, 2010 | 07:23 PM
oldalaskaman's Avatar
oldalaskaman
you need to put new bushings in it , mine did exactly the same thing,
Old Nov 25, 2010 | 11:30 PM
LaVidaLoca's Avatar
LaVidaLoca
Where did you find the bushings? Last time I rebuilt a headlight I ended up making a set on my lathe which took a long time.
Old Nov 26, 2010 | 11:40 AM
oldalaskaman
corvette Specialties has them , also mid america, they average about $6.00, the shipping costs more than the parts.
Old Nov 26, 2010 | 12:42 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
http://www.corvettefever.com/howto/33098/index.html
Peep this article while you wait for your bushings to arrive.
Old Nov 26, 2010 | 07:08 PM
91yellowfellow's Avatar
91yellowfellow
how hard is it to put these bushings in?
Old Nov 26, 2010 | 07:14 PM
oldalaskaman
It just takes time and a little patience, Its easiest to remove the complete light and disassemble it on a bench. make sure to mark an outline on your hood to make reinstalling them in the original spot easier. It wiil take longer to remove the light and remove the motor from the horseshoe than putting the bushings in. Make sure you clean all the old material out and use a small amount of grease on assembly
Old Nov 26, 2010 | 07:18 PM
91yellowfellow
ok so def doable..... Thanks for the info...
Old Nov 26, 2010 | 08:02 PM
oldalaskaman
first one will take awhile, the 2nd will go quick
Old Nov 27, 2010 | 01:46 PM
george4's Avatar
george4
If it is the c clip that fits on a ¼ shaft, pm me with your address and I send you a freebie on Monday. I had to buy a packet of them when I did my headlamp motors and lost one. These are from McMaster Carr, stainless. You will also need a small washer between the clip and arm that also probably fell off.
Anybody else that needs a clip, likewise pm me, I have 4-5 extra.
To Headlight Issue
