Winter Projects, Whats everyone doing?
Old Dec 2, 2010 | 02:06 PM
RedLS1GTO's Avatar
RedLS1GTO
Starting at the back and working to the front. Not too many bolts that won't be turned during the off season on the race car.
Old Dec 2, 2010 | 02:17 PM
Redghost's Avatar
Redghost
St. Jude Donor '10
Replace heater core. (Started on this last night.)
Replace outer door window weather stripping.
It's going to be "back to a Garage Queen" for a, hopefully, short period of time.
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I wish my garage was heated, the weather has been weird in SoCal, 30-35 at night and on the weekends when I'm off it has been raining.
On both Vettes I have to replace the water pump oil seal. I bought the special nipple tool so, I'll finally do it correctly. On the 96 I got to replace the PKE module and the horn wires.
On my DD (Focus), I want to upgrade the suspension to an Eicbac Street Performer Kit. It costs $700, I already bought rotors and steel braided lines for it. Two years ago, I upgraded to the SVT brake system and the K&N snorkel.
Old Dec 2, 2010 | 02:24 PM
xsalvioutlawx's Avatar
xsalvioutlawx
Well I'm in California so I don't put the Vette away for the winter.
But...My car has a bog/hesitation sometimes whenever I want to go alot faster.
From the search feature, I've came up with it's either the injectors or the fuel pump.
Still have yet to test it, but I plan to get around to it this weekend.
Old Dec 2, 2010 | 07:54 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Pull old motor and install new to me 383
Lightweight flywheel and new clutch
New clutch master and slave
New Aluminum seats
Harnesses
almost forgot - adjustable lower control arm bushings
Then get on the cage builders list for a full cage sometime next year.
Any money left over - big brake kit
Old Dec 2, 2010 | 09:28 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
I dropped my motor off a few weeks ago to do a 383 rebuild. It was a LE2 top end. It will now get a forged, internally balanced stoker crank,rods and pistons. Clean up the LE2 heads and spec a new cam for the 383 build.
PeteK has the transmission and it will be done when its done. Hopefully it will be back together by February or March.
I will also be changing out the shocks and may do new bushings too.
Old Dec 2, 2010 | 09:33 PM
KARR's Avatar
KARR
Originally Posted by fc_soldier
Wondering what everyone plans to do this winter before 2011 vette season. My plans
C5 Brake upgrade (bought it, need to install)
Toledo Cowl Hood (bought it, need to install)
LvL 5 4l60E (Waiting to buy)
If santa treats me good maybe Ill by my Magnacharger ( Hoping to buy).
If you started let us know how its going.
Well, I was planning to peel off the top and take a cruise! GOD BLESSED TEXAS!!
Old Dec 2, 2010 | 09:43 PM
blr33439's Avatar
blr33439
Finishing my headlight project. After that, shopping for my next C4.
Old Dec 2, 2010 | 10:47 PM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
I finished my "winter project" a couple of weeks ago.
I took off the chrome ZR-1 type wheels and put the stock wheels on.
I am so looking forward to my "spring project".
Old Dec 2, 2010 | 11:21 PM
rickyrj1's Avatar
rickyrj1
Nice I wanna see some pics of these projects
Will Do, brakes & delete brace almost done.
Old Dec 2, 2010 | 11:57 PM
mechguy79's Avatar
mechguy79
Tackling interior. I desparately need a new stereo and need to address the rattling. Also need to replace parts in the doors.
Old Dec 3, 2010 | 08:44 AM
blue94's Avatar
blue94
Dropping the auto for a ZF, new oil pan, and DRM brackets. Maybe more if budget can handle (rear links and rods). Then maybe cleaning out the Garage.
Old Dec 3, 2010 | 06:34 PM
  #33
RUU's Avatar
RUU
Lots to do on mine, hence it's at home in the garage this winter instead of in storage off-site;
Upper control arm bushings (bought, need to install*)
Upper ball joints (bought, need to install*)
Front brake pads (bought, need to install*)
Outer door window seals (bought, need to install*)
Parking brake cables (bought, need to install*)
Also have plugs & wires en-route & may tackle the opti (& water pump, by default) while I'm in there.
*If I get cold and/or lazy this winter, look for me on a future episode of "Hoarders"
Old Dec 3, 2010 | 08:42 PM
  #34
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Just a helpful hint - Unless you have a press and make yourself a spacer the best way to do the bushings in the upper control arms is to take them to a machine shop and have them do it. I had a local shop do my upper bushings, remove the upper ball joint and press out and install the lower ball joint so I didn't learn too many new cuss words when I did my suspension rebuild
Old Dec 3, 2010 | 08:58 PM
  #35
RUU's Avatar
RUU
I'm with you there. I had the local shop press in the new lower ball joints after I gave up trying to get them in with the c-clamp style loaner press.
Old Dec 4, 2010 | 12:48 AM
  #36
fc_soldier's Avatar
fc_soldier
Did my hood but I need to send to the shop to get fitted and shaved alittle. Get some paint and Ill post so pics.
Old Dec 4, 2010 | 12:59 AM
  #37
McGirk94LT1's Avatar
McGirk94LT1
Plan is to turn this
[IMG][/IMG]
Into something close to this
[IMG][/IMG]
Ive wanted to do this for so long now, went checking out powdercoating places and the work involved to freshen the wheel up and only coat those small areas was not worth the price. So guess Ill just be doin a lot of scrubin and paintin myself in the garage. Then again the vette may be on the auction block come spring for something different and the reaction most gave me when i posted this once wasnt that great. So maybe ill just leave them be
Old Dec 4, 2010 | 01:21 AM
  #38
61FUN's Avatar
61FUN
Navigator
On Vert leather skin and foam on passenger seat, drivers is done, change oil. On '61 Impala tubular A arms. '32 Ford PU - get it on the road!!!
Old Dec 4, 2010 | 07:57 AM
  #39
Moon86's Avatar
Moon86
1- Dewitts rad fan upgrade
2- Clean rad and ac condenser
3- Install plate style trans cooler
4- Put new gears in left headlight motor
5- Install trans temp and pressure gauges.
6- Clean engine compartment up
7- Get underhood lights working but with a manual switch
8- Inspect driveline and suspension and replace needed parts
8- Change rear gear oil, brake fluid, ps fluid, and trans fluid
9- Install KYB shocks
10- Install breadbox eliminator.
11- Finish my Cyberdybe gauge install
12- Install new carpet and sound deadner
13- New rear y pipe and mufflers
My winter garage time is about 3 1/2 months so I should be able to get all that done. Everything that makes the car more reliable gets priority.
