Light cluster
Old Apr 7, 2002 | 07:32 PM
aldo802's Avatar
aldo802
Default Light cluster
Does anyone out there know how to fix the panel lights?? Just my speedomter is lit!! I have a 1986!
Old Apr 7, 2002 | 07:52 PM
vader86's Avatar
vader86
Default Re: Light cluster (aldo802)
is it just the lights? (you could still see the digits they just dont light up)
If its just the lights, remove the bezel on top of the dash unit, and there are 4 little silver things that twist and come out, you should replace all 4 bulbs.
The bulb # is Sylvania 882, found at Pep Boys. The trick is gettin the little buggers in, you CANT touch them with fingers, oils from your hands make them get hot and they blow up sooner.
Old Apr 7, 2002 | 08:02 PM
HG's Avatar
HG
You may have to have the digital dash cluster repaired. Check in the Tech tips area, they have a complete description on how to pull out the cluster. This is a commom problem with digital dash. Good Luck :seeya
Old Apr 7, 2002 | 08:13 PM
aldo802's Avatar
aldo802
Default Re: Light cluster (HG)
What is the bezel?? On top of the dash???????
Old Apr 7, 2002 | 08:14 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
The bezel is the plastic piece surronding the gauges.
Old Apr 7, 2002 | 08:16 PM
aldo802's Avatar
aldo802
U mean unscrew the plastic that is in front in the dash!! Yes my digits r still there!! My speedometer is still lit but not the rest of the cluster!
Old Apr 7, 2002 | 08:18 PM
aldo802's Avatar
aldo802
Default Re: Light cluster (Mr Mojo)
Crap I had that off, too!!! I'll do it tomarrow!! and there is 4 bulbs there U say??? I looked but didn't c them!!
Old Apr 7, 2002 | 08:20 PM
vader86's Avatar
vader86
yes remove the bezel, and be sure to replace all 4 bulbs underneath those round silver tabs
Old Apr 7, 2002 | 08:21 PM
aldo802's Avatar
aldo802
Default Re: Light cluster (vader86)
Thanks I''ll take a look again tomarrow! Al!
To Light cluster
