Need Headlight motor part #
Old Apr 8, 2002 | 01:19 PM
TIMSPEED's Avatar
TIMSPEED
Default Need Headlight motor part #
I need the part # and price for a 84-87 Corvette Drivers Side Headlight motor. Or maybe someone can recommend a place to get this part from. THANKS!
Old Apr 8, 2002 | 01:22 PM
scorp508's Avatar
scorp508
Discontinued.
Get a reman one from Ecklers for $130 + $100 core charge. Or for $500 upgrade to the 88-95 models.
Old Apr 8, 2002 | 01:30 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: (scorp508)
$230 EACH?!?! OUCH!!! But I guess I HAVE to. DAAANG! Ohh well, the insurance is paying for it. Still :( I was thinking about putting the other side on there too, because it's making noise when it flips up, but for that price! Forget that! :eek:
Old Apr 8, 2002 | 01:34 PM
scorp508's Avatar
scorp508
No. $130 each. You are charged $230 and then refunded $100 when you send in your original ones. Although you may get zilch back if they are busted up.
Old Apr 8, 2002 | 01:35 PM
TIMSPEED's Avatar
TIMSPEED
Yeah..mine's busted :( That's gonna be stupid, one making noise, the other quiet. How much are factory ones? Cuz that's the price they're going to give me. Are they more than $230?(Hopefully!)
Old Apr 8, 2002 | 01:41 PM
scorp508's Avatar
scorp508
The following makes no sense to me, but I got it off of my Alldata account.
Headlamp Motor
Actuator
Right . 16500364 . $242.00
Left . 16517068 . $953.00
Actuator Kit . 16517068 . $953.00
Also, there is a Technical Service Bulleting to upgrade the 84-87 to the later style. If you are smart, you'll push for this. The GM list price is shown at $972 for the part # stated in the TSB below.
Number: 87-309-8B
Section: 8B
Date: March 1991
Corporate Bulletin No.: 138202R
Subject: HEADLAMP DOOR ACTUATOR KITS
Model and Year: 1984-87 CORVETTE
The headlamp door actuators for the 1984 thru 1987 "Y" Car are no longer available. A kit (P/N 16517068) is now available to convert the 1984 thru 1987 Y car to the 1988 and newer "Y" car headlamp system. The package contains both the right-hand and left-hand retractable headlamp assemblies with actuators (minus the capsules), the control module, adapter harnesses, and detailed instructions.
If further service is needed in the future, all parts from the 1988 or newer model year may be used. An appropriate notation will be made in the Parts Catalog.
Installation Notes:
1. Some of the kits may have headlamp actuator connectors that are wired backwards. If the one or both headlamp doors operate backwards after the kit is installed, reverse the terminals in the connector to the actuator.
2. It is important that all wiring connections be soldered, and protected with self-sealing electrical tape or heat-shrink tubing.
3. Headlamps should be aimed after the kit is installed.
Parts are currently available from GMSPO.
Labor Operation Number: T1705,
Labor Time: 2.7 Hours
Trouble Code: 92
[Modified by scorp508, 12:42 PM 4/8/2002]
Old Apr 8, 2002 | 01:45 PM
TIMSPEED's Avatar
TIMSPEED
$972?!!? WHOA! Can't be. I'll have to talk to the guy at the body shop, see what the ACTUAL piece is that he needs. Be it actuator or what. Cuz if they want to give me $950 for a part I paid $250 for...then WHOA!
Old Apr 8, 2002 | 02:00 PM
scorp508's Avatar
scorp508
The way I read it $972 is the list price for the entire upgrade kit to 88-96 specs. Probably the same kit Ecklers has for $500.
Old Apr 8, 2002 | 02:10 PM
TIMSPEED's Avatar
TIMSPEED
Yup, it's the Drivers Side Actuator I need, guy at the body shop said list price was $242 and it was discontinued. SO, I won't be gaining anything on that then. Ohh well.
To Need Headlight motor part #
