02 sensor help
Old Dec 31, 2010 | 10:10 AM
bacord's Avatar
bacord
Default 02 sensor help
I used the search and from what I read there are 2 02 sensors for a 95 LT1 auto. The auto parts store told me that there are 4. 2 upstream and 2 downstream. I can only find the 2 right below the exhaust manifold am I missing the other 2?? I only get 22 M.P.G. at at 70 M.P.H. and was suggested by forum members that I change the 02 sensors and there is no codes. When idleing I can smell unburned gas but runs great otherwise. Thanks for all the help I've got here the last year or so.
Old Dec 31, 2010 | 10:26 AM
wnafly's Avatar
wnafly
96 is when they changed to OBD2. Mine has 4. Before and after the cats. I'm not sure how many you have. Other experts will chime in and give you the correct answer I'm sure.
Old Dec 31, 2010 | 10:38 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
The 95's have 4, two in front of the cats, two in back. If someone has replaced the exhaust with a "cat back" system they may have been eliminated. The 95 uses a "hybrid" system. It has the computer for OBD2, but is still an OBD1 system. The front 02's are the ones that adjust for fuel mixture, the rears look for changes after the cats. I would check your plugs for even burning between the cylinders (you may have bad injectors).
Old Dec 31, 2010 | 10:45 AM
bacord's Avatar
bacord
I'll have to look closer not much room under the vette. I replaced all injectors with some from jon at F.I.C. Thanks
Old Dec 31, 2010 | 10:52 AM
bacord's Avatar
bacord
WWCFC4GDD Change all 4 or just the 2 upstream. Still not sure if there is 4 as the car is still hot but will check in about an hour. Thanks
To 02 sensor help
