Spark Plug Replacement Help
Old Jan 13, 2011 | 10:02 PM
Troy.Blackburn's Avatar
Troy.Blackburn
Default Spark Plug Replacement Help
What's the best way to get to the #2 Spark Plug on a 90 Vette (Base Model)? It's pretty tight in there under the Air Conditioning compressor and so on.
Thank You
Troy
Old Jan 13, 2011 | 10:07 PM
Sky Vette's Avatar
Sky Vette
Remove the center wheelwell plastic piece that goes up over the right shock. With a long extention and swivel and a little luck you can access that plug from the wheelwell area.
Old Jan 13, 2011 | 11:25 PM
higgyburners's Avatar
higgyburners
I believe in the Beer Fairy
St. Jude Donor '15,'19
i agree i just did my 93 and used the same method
Old Jan 13, 2011 | 11:26 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
I was changing plugs in these things before I new it was suppose to be hard.
Old Jan 14, 2011 | 04:29 AM
Paul Workman's Avatar
Paul Workman
What's the big deal?
There's more than ONE reason to like the LT5!
P.
Old Jan 14, 2011 | 06:55 AM
Troy.Blackburn
P.
Yup, I've got one of these too. Obviously I'm not asking about changing the plugs for that car.
Old Jan 14, 2011 | 06:16 PM
steverichmond's Avatar
steverichmond
Cylinder #8 on a LT1 is murder. Took me long time to find the right tool combo.
Steve
Old Jan 14, 2011 | 08:52 PM
higgyburners
Steve
i used a swivel head ratchet,spark plug socket with hex end and a small extension to get #8
Old Jan 14, 2011 | 09:23 PM
tblt44's Avatar
tblt44
All 8 easy with the right tool combination
Old Jan 15, 2011 | 01:29 AM
Azriel's Avatar
Azriel
I did some combination of this until it was vaguely tight enough. One time, I didn't shove in the wire hard enough, and it came loose going down the road. By then, the engine was at temp, and I had to pull over to shove it back in. That was an unpleasantly hot experience.
Old Jan 15, 2011 | 08:41 AM
larry93lt1's Avatar
larry93lt1
From: Gaithersburg MD A member since 2007 but then the computer crashed and then the car crash loss of memory X 2
The best tools I've found is a cool engine and a lot of patience.
Old Jan 15, 2011 | 09:09 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
You can do it without removing it, but it makes it soooo much easier!
Old Jan 15, 2011 | 09:16 AM
steverichmond
I need to get a swivel head ratchet next time I'm out. I seem to have come across several instances lately where it would have been handy.
Old Jan 15, 2011 | 03:00 PM
HlhnEast's Avatar
HlhnEast
Pretty much a necessity for Corvette plus all manner of sizes of extensions.
Old Jan 15, 2011 | 03:31 PM
higgyburners
nothing is worse than having to do #7 twice ... first plug broke off at the base of the ceramic insulator, i swear i had that socket fully seated anyway it pays to buy 9
Old Jan 15, 2011 | 05:05 PM
steverichmond
Since you brought it up first. I did the same thing. Glad to know I'm not the only one.
Old Jan 15, 2011 | 05:10 PM
WW7's Avatar
WW7
Since putting headers on my car the plug changing has gotten much easier. I got the headers without egr or air and I can change plugs in 20 minites now..No chit...WW
Old Jan 16, 2011 | 12:50 AM
yaknow's Avatar
yaknow
I've owned a couple of C4's over the past 20+ years, in the begining I had only a lousy Hanes manual and no internet to tell me it was difficult.
To Spark Plug Replacement Help
