Exhaust System
Old Jan 17, 2011 | 12:19 PM
BBExhaust's Avatar
BBExhaust
Premium Supporting Vendor
johnnyboy
Listening in person is by far the best way to choose a system however that is not always a possibility. There are 3 things we look at when we develop an exhaust system and they are the same you should consider when purchasing one as well, they are performance, sound and style.
We get numerous phone calls every week asking the same question as you and my first question back is "what exactly are you looking for from an exhaust"? Are you looking for the most performance you can get and sound level isn't a concern? Is sound level and note more important or are you just looking for something to look better. Once I narrow it down with these and other questions I can then determine which system we offer that would best suit your needs.
I am pretty confident that I can determine which one of our systems will best fit anyone's needs after talking with them for a little while and getting a feel for what they are after. And while we do not guarantee sound because it is so subjective if you do purchase a B&B and don't like something about it we will do everything possible to make you a satisfied customer.
__________________
David Merkel
Marketing Dir.
Billy Boat Exhaust
Old Jan 17, 2011 | 12:56 PM
Marv02's Avatar
Marv02
So what you saying in a nut shell if you put just about any mufflers with cross tube will eliminate the Drone.
Like I said I want a louder system at idel only If I went to a diffrent muffler with my rear cross over tube it still be Quite at cruise speeds.
Originally Posted by RetiredSFC 97
Whatever you decide I highly recommend the rear Y with a crossover tube. It helps to balance out the resonance and reduces and even eliminates any drone you may have with certain mufflers.
Couple thoughts
Expensive doesn't mean the best, everyone likes different sounds and has different wants/needs, so do your homework and take your time so you don't make a 1000 dollar mistake. There have been many people take the advice of others and it turned out it wasn't what they were looking for.
Old Jan 17, 2011 | 02:11 PM
ch@0s's Avatar
ch@0s
No! Most systems have drone. I really suggest doing your homework.
As far as i know the Corsa is the only one with no drone. The magnaflow for me had none. Some have reported drone with the magnaflow but very little. The new design B&B according to B&B has no drone.
Old Jan 17, 2011 | 02:35 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
It won't eliminate it on all mufflers but it will reduce it on them and eliminate it completely on others.
That's what it was designed for. It kinda works on the same principle as the corsa mufflers. On the corsa you have on outlet that is the primary outlet and the other outlet takes buildup pressure, and shoots it out the other outlet. That buildup pressure is what causes drone.
Old Jan 17, 2011 | 02:36 PM
RetiredSFC 97
Sometime I think that some people don't know the difference between drone and the sound of the muffler.
Old Jan 17, 2011 | 02:38 PM
Sandpiper59's Avatar
Sandpiper59
I wish I could answer to the question of drone but can't for another 4 months (snow). But, I just put a Pypes system on mine, right from the manifolds back, no cats. The Pypes is meant to be header back or with the addition of their down pipes, factory header and back. It won't do from the center cat and back though. It is very mellow at idle with a slight increase in deep rumble at higher RPM's and an outright bark at full throttle near redline. System is 2.5" stainless, mandrel and streight through but packed mufflers nearly the same as Magnaflow mufflers. It does have a cross over (true X, not 'H' pipe) to help with drone and flow, but without any cats or resonators I am not expecting quiet! It is substantially cheaper than most other options though.
Greg
Old Jan 17, 2011 | 03:10 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Huh??? Can't hear ya Mike.
Old Jan 17, 2011 | 03:36 PM
RetiredSFC 97
What?
Old Jan 17, 2011 | 03:58 PM
ch@0s's Avatar
ch@0s
I would not be surprised.
If you have a headache and your teeth are rattling.. it's drone.
Old Jan 17, 2011 | 06:15 PM
redvetttes's Avatar
redvetttes
Originally Posted by johnnyboyC4
As expensive as exhausts go, I just don't want to make a $1000 mistake. Thanks, guys.
As long as it cover up the hi pitch wine coming from the passenger seat (wife) its a great sound
Old Jan 17, 2011 | 06:39 PM
93Rubie's Avatar
93Rubie
If it is too loud, you are to old...
http://www.youtube.com/watch?v=0ZVpL6K2cJw
Old Jan 17, 2011 | 06:56 PM
Sweet 90's Avatar
Sweet 90
OR MARRIED
Fixed
Old Jan 17, 2011 | 07:43 PM
  #33
CAJUN C4's Avatar
CAJUN C4
Or you could just go buy some magnaflows and be done with it
Probably the Best Sounding best flowing (Straight Through) w/o Int. Resonance Mufflers going. IMHO
P/N: 324337 with LT1 Tips. $259 per. Pair....Corvette Central
Old Jan 17, 2011 | 07:45 PM
  #34
ch@0s's Avatar
ch@0s
It's not the loud that bothers me it's drone.
Old Jan 17, 2011 | 08:23 PM
  #35
socalman's Avatar
socalman
St. Jude Donor '10
well then, tell her to keep her yap shut!
Old Jan 17, 2011 | 08:40 PM
  #36
Baldfart's Avatar
Baldfart
I have a Magna-Flo. It does have a drone, but it doesn't really bother me. I would buy one again.
Old Jan 17, 2011 | 08:44 PM
  #37
ch@0s's Avatar
ch@0s
Shhh! she is 10 feet from me.
To Exhaust System
Old Jan 18, 2011 | 10:03 PM
  #38
mdell2's Avatar
mdell2
I did much research before I finally decided to go with muffler eliminators. I went down to my local muffler shop, he cut off my stock mufflers, he had a take off c6 system so he cut off the tips from that and welded them onto to pipes from where he cut mine off, painted every thing black underneath the car and wow. A great sound for little $$$. Do it before you buy anything else, you wont be sorry. Not too loud, almost no drone, and an incredible sound. Looks great too boot. If they don't have any old c6 tips, just pick out a nice set that you like for around $40 to $50 and again wow.
Old Jan 18, 2011 | 10:27 PM
  #39
Marv02's Avatar
Marv02
I have looked in to muffler eliminators my self I just scrared it be to loud.
I running turn down straight out my Full lenght headers for now until I save some more money to have the New cat and Y pipe made to hook to my Magna Flows.
I know the car sounds Great But LOUD very loud I wish I could keep it this way but it a ticket waiting to happen.
I been thinking getting the tubes cat back enlarged to get more noise out of them they are 2 1/4 inch now.
Old Jan 21, 2011 | 07:41 PM
  #40
CAJUN C4's Avatar
CAJUN C4
Agreed...I love mine..No Drone just a great 60's Sound.
I have an "X" Pipe in place of the resonator and no drone at all.
Thanx RetiredSFC 97 for recommending them to me.
